1 - 20 of 24 Posts
whats the best brand of replacment battery for a stock 91 bronco ??? (no winch, lights, etc.)
Try it now!!
Im a fan of the yellow top Optimas. No reason to pass up deep cycle ability for a red top. I've had both and I cant tell a difference besides having the deep cycle ability the red top didnt have.
And mine turns over a 460 that might have the York and AC compressors engaged at startup.
-Will
89 XLT 460
I ♥ TTB
One advantage to passing on the yellow top and going with the red is the warranty. 1 year free vs. 3 years free... Especially if you're not really going to be deep cycling it...
The biggest advantage of the optima (red or yellow, or any other color for that matter) is their durability to hold up under vibration.
But if you don't want to go with the best, you're pretty safe with pretty much anyones battery as long as they are offering a good warranty. Most reputable companies buy their batteries from the top 3 manufacturers and are pretty comparable.
Banned
For less than half the money of an Optima, you get more than double the warranty & local exchange wherever you happen to be if it ever gives you problems. It also has more CA, more CCA, & more reserve minutes. If you need to mount it sideways or punch holes in it, buy the Optima. If not, buy the Motorcraft.
Wrenching for a Livin'
im with steve on this one. Don't waste money on the optima is the motorcraft will work for what you need
Costco has some cheap batteries that have a 3 year free replacement. I got mine for $50.00 and its a 1000CCA.
Discussion Starter #12
well, i went to the interstate store and they tested my megatron, said it was above what they spec the new ones at...
so i guess im now looking for a replacement starter, dangit...
thanks guys
My starter was a pain in the neck to replace. Its kinda hard to get to the bolts and one of mine was frozen.
We took the old one to advance auto to get it tested to make sure it was really bad...The guy hooked it up to the machine and started it up. It started makin a grindin noise and shot out a bunch of sparks. The guy kinda jumped back then turned it off. He came up to me and said "Damn, man your shit's dead."
Make sure its just not a dirty wire on your starter. I had a problem with my Bronco not wanting to turn over and pulled my starter and hooked it with jumper cables to the battery and it worked fine. I noticed when I put it back in the little wire that ran to the solenoid was corroded up. Cleaned it all off real good and fired right up and never had another problem.
I ♥ TTB
make sure all your connections are clean and tight as well at the battery and the starter
miesk5 said:
Johnson Controls produces both Optima & the Motorcraft Silver BXT-65-850 plus units for Sears (DieHard Gold), Auto Zone (Duralast Gold), Eveready, Everstart, Interstate, Pep Boys (ProStart & Energizer). Toyota (TrueStart), Mitsubishi (Diamond Car Care), Mazda, Advance Auto (Autocraft Titanium), Costco (Kirkland Signature), etc.
BXT-65-850
CCA: 875 @ 0 degree F/1090 @ 32 degree F; 165 RC
Warranty - Months: 100 mos. pro-rata (36 mos. free replace.)
ref: Steve's pic & autobatteries.com (a Johnson site) , etc.
here is the Motorcraft Buyers Guide Application Guide:
Part No.: BXT-65-850
Manufacturer: MOTORCRAFT
Part Type: BATTERY, STANDARD AUTOMOTIVE
Total No. of Vehicles: 439
FORD (298)
BRONCO (26)
1987 4.9L 300cid Fuel Injected L6 Vin:Y
1987 5.0L 302cid Fuel Injected V8 Vin:N
1987 5.8L 351cid 4 Barrel V8 Vin:H
1988 4.9L 300cid Fuel Injected L6 Vin:Y
1988 5.0L 302cid Fuel Injected V8 Vin:N
1988 5.8L 351cid Fuel Injected V8 Vin:H
1989 4.9L 300cid Fuel Injected L6 Vin:Y
1989 5.0L 302cid Fuel Injected V8 Vin:N
1989 5.8L 351cid Fuel Injected V8 Vin:H
1990 4.9L 300cid Fuel Injected L6 Vin:Y
1990 5.0L 302cid Fuel Injected V8 Vin:N
1990 5.8L 351cid Fuel Injected V8 Vin:H
1991 4.9L 300cid Fuel Injected L6 Vin:Y
1991 5.0L 302cid Fuel Injected V8 Vin:N
1991 5.8L 351cid Fuel Injected V8 Vin:H
1992 4.9L 300cid Fuel Injected L6 Vin:Y
1992 5.0L 302cid Fuel Injected V8 Vin:N
1992 5.8L 351cid Fuel Injected V8 Vin:H
1993 5.0L 302cid Fuel Injected V8 Vin:N
1993 5.8L 351cid Fuel Injected V8 Vin:H
1994 5.0L 302cid Fuel Injected V8 Vin:N
1994 5.8L 351cid Fuel Injected V8 Vin:H
1995 5.0L 302cid Fuel Injected V8 Vin:N
1995 5.8L 351cid Fuel Injected V8 Vin:H
1996 5.0L 302cid Fuel Injected V8 Vin:N
1996 5.8L 351cid Fuel Injected V8 Vin:H
BRONCO II (2)
1989 2.9L 177cid Fuel Injected V6 Vin:T
1990 2.9L 177cid Fuel Injected V6 Vin:T
COUNTRY SQUIRE (4)
1988 5.0L 302cid Fuel Injected V8 Vin:F
1989 5.0L 302cid Fuel Injected V8 Vin:F
1990 5.0L 302cid Fuel Injected V8 Vin:F
1991 5.0L 302cid Fuel Injected V8 Vin:F
CROWN VICTORIA (9)
1992 4.6L 281cid Fuel Injected V8 Vin:W
1993 4.6L 281cid Fuel Injected V8 Vin:W
1994 4.6L 281cid Fuel Injected V8 Vin:W
1995 4.6L 281cid Fuel Injected V8 Vin:W
1996 4.6L 281cid Fuel Injected V8 Vin:6
1996 4.6L 281cid Fuel Injected V8 Vin:9
1996 4.6L 281cid Fuel Injected V8 Vin:W
1997 4.6L 281cid CNG/FI V8 Vin:9
1998 4.6L 281cid CNG/FI V8 Vin:9
ECONOLINE E150 1/2 TON (18)
1993 4.9L 300cid Fuel Injected L6 Vin:Y
1994 4.9L 300cid Fuel Injected L6 Vin:Y
1995 4.9L 300cid Fuel Injected L6 Vin:Y
1996 4.9L 300cid Fuel Injected L6 Vin:Y
1997 4.2L 256cid Fuel Injected V6 Vin:2
1997 4.6L 281cid Fuel Injected V8 Vin:6
1997 5.4L 330cid Fuel Injected V8 Vin:L
ECONOLINE E250 3/4 TON (20)
1994 7.5L 460cid Fuel Injected V8 Vin:G
1995 4.9L 300cid BIFUEL/FI L6 Vin:Z
1995 7.5L 460cid Fuel Injected V8 Vin:G
1996 4.9L 300cid BIFUEL/FI L6 Vin:Z
1996 7.5L 460cid Fuel Injected V8 Vin:G
ECONOLINE E350 1 TON (23)
1992 7.3L 444cid Diesel V8 Vin:M
1992 7.5L 460cid Fuel Injected V8 Vin:G
1993 7.3L 444cid Diesel V8 Vin:M
1993 7.5L 460cid Fuel Injected V8 Vin:G
1994 7.3L 444cid Diesel V8 Vin:M
1995 7.3L 444cid Diesel V8 Turbo Vin:F
1996 7.3L 444cid Diesel V8 Turbo Vin:F
F53 STRIPPED CHASSIS (1)
F59 STRIPPED CHASSIS (2)
LTD CROWN VICTORIA (8)
1988 5.8L 351cid 2 Barrel V8 Vin:G
1989 5.8L 351cid 2 Barrel V8 Vin:G
1990 5.8L 351cid 2 Barrel V8 Vin:G
1991 5.8L 351cid 4 Barrel V8 Vin:G
MUSTANG (4)
1988 5.0L 302cid Fuel Injected V8 Vin:E
1989 5.0L 302cid Fuel Injected V8 Vin:E
1990 5.0L 302cid Fuel Injected V8 Vin:E
1991 5.0L 302cid Fuel Injected V8 Vin:E
MUSTANG COBRA (2)
1996 4.6L 281cid Fuel Injected V8 Vin:V
1996 4.6L 281cid Fuel Injected V8 Vin:X
MUSTANG GT (2)
PICKUP F150 1/2 TON (22)
1994 5.8L 351cid Fuel Injected V8 Vin:R
1995 5.8L 351cid Fuel Injected V8 Vin:R
PICKUP F150 LIGHTNING (4)
1993 5.8L 351cid Fuel Injected V8 Vin:R
PICKUP F250 3/4 TON (43)
1987 7.5L 460cid 4 Barrel V8 Vin:L
1988 7.3L 444cid Diesel V8 Vin:M
1988 7.5L 460cid Fuel Injected V8 Vin:G
1989 7.3L 444cid Diesel V8 Vin:M
1989 7.5L 460cid Fuel Injected V8 Vin:G
1990 7.3L 444cid Diesel V8 Vin:M
1990 7.5L 460cid Fuel Injected V8 Vin:G
1991 7.3L 444cid Diesel V8 Vin:M
1991 7.5L 460cid Fuel Injected V8 Vin:G
1993 7.3L 444cid Diesel V8 Turbo Vin:C
1994 7.3L 444cid Diesel V8 Turbo Vin:F
1994 7.3L 444cid Diesel V8 Turbo Vin:K
PICKUP F350 1 TON (32)
PICKUP F450 SUPER DUTY (14)
1995 7.3L 444cid Diesel V8 Vin:F
RANGER (17)
1989 2.3L 140cid Fuel Injected L4 Vin:A
1990 2.3L 140cid Fuel Injected L4 Vin:A
1991 2.3L 140cid Fuel Injected L4 Vin:A
1991 2.9L 177cid Fuel Injected V6 Vin:T
1991 3.0L 183cid Fuel Injected V6 Vin:U
1992 2.3L 140cid Fuel Injected L4 Vin:A
1992 2.9L 177cid Fuel Injected V6 Vin:T
1992 3.0L 183cid Fuel Injected V6 Vin:U
1993 2.3L 140cid Fuel Injected L4 Vin:A
1993 3.0L 183cid Fuel Injected V6 Vin:U
1994 2.3L 140cid Fuel Injected L4 Vin:A
1994 3.0L 183cid Fuel Injected V6 Vin:U
1995 2.3L 140cid Fuel Injected L4 Vin:A
1995 3.0L 183cid Fuel Injected V6 Vin:U
1996 3.0L 183cid Fuel Injected V6 Vin:U
TAURUS (15)
1986 2.5L 153cid Fuel Injected L4 Vin:D
1987 2.5L 153cid Fuel Injected L4 Vin:D
1988 2.5L 153cid Fuel Injected L4 Vin:D
1988 3.8L 232cid Fuel Injected V6 Vin:4
1989 2.5L 153cid Fuel Injected L4 Vin:D
1989 3.8L 232cid Fuel Injected V6 Vin:4
1990 2.5L 153cid Fuel Injected L4 Vin:D
1990 3.8L 232cid Fuel Injected V6 Vin:4
1991 2.5L 153cid Fuel Injected L4
1991 2.5L 153cid Fuel Injected L4 Vin:D
1991 3.8L 232cid Fuel Injected V6 Vin:4
1992 3.8L 232cid Fuel Injected V6 Vin:4
1993 3.8L 232cid Fuel Injected V6 Vin:4
1994 3.8L 232cid Fuel Injected V6 Vin:4
1995 3.8L 232cid Fuel Injected V6 Vin:4
THUNDERBIRD (20)
1987 2.3L 140cid Fuel Injected L4 Turbo Vin:W
1988 2.3L 140cid Fuel Injected L4 Turbo Vin:T
1989 3.8L 232cid Fuel Injected V6 Supercharged Vin:C
1989 3.8L 232cid Fuel Injected V6 Supercharged Vin:R
1990 3.8L 232cid Fuel Injected V6 Supercharged Vin:R
1991 5.0L 302cid Fuel Injected V8 Vin:T
1992 5.0L 302cid Fuel Injected V8 Vin:T
1993 5.0L 302cid Fuel Injected V8 Vin:T
THUNDERBIRD SC (5)
1991 3.8L 232cid Fuel Injected V6 Supercharged Vin:R
1992 3.8L 232cid Fuel Injected V6 Supercharged Vin:R
1993 3.8L 232cid Fuel Injected V6 Supercharged Vin:R
1994 3.8L 232cid Fuel Injected V6 Supercharged Vin:R
1995 3.8L 232cid Fuel Injected V6 Supercharged Vin:R
VAN E SUPER DUTY (4)
WINDSTAR (1)
LINCOLN (39)
CONTINENTAL (13)
1984 2.4L 146cid Diesel L6 Turbo Vin:L
1985 2.4L 146cid Diesel L6 Turbo Vin:L
1985 5.0L 302cid Fuel Injected V8 Vin:F
1986 5.0L 302cid Fuel Injected V8 Vin:F
1995 4.6L 281cid Fuel Injected V8 Vin:V
MARK VII (13)
1985 5.0L 302cid Fuel Injected V8 Vin:M
1986 5.0L 302cid Fuel Injected V8 Vin:M
1987 5.0L 302cid Fuel Injected V8 Vin:F
1987 5.0L 302cid Fuel Injected V8 Vin:M
1992 5.0L 302cid Fuel Injected V8 Vin:E
TOWN CAR (13)
1991 4.6L 281cid Fuel Injected V8 Vin:W
1997 4.6L 281cid Fuel Injected V8 Vin:W
1998 4.6L 281cid Fuel Injected V8 Vin:W
MAZDA (15)
B2200 (5)
1991 2.2L 2184cc 2 Barrel L4 Vin:F2
1991 2.2L 2184cc Fuel Injected L4 Vin:F2
1992 2.2L 2184cc 2 Barrel L4 Vin:F2
1992 2.2L 2184cc Fuel Injected L4 Vin:F2
1993 2.2L 2184cc Fuel Injected L4 Vin:F2
B2300 (1)
1994 2.3L 2295cc Fuel Injected L4 Vin:A
B2600i (3)
1991 2.6L 2606cc Fuel Injected L4 Vin:G6
1992 2.6L 2606cc Fuel Injected L4 Vin:G6
1993 2.6L 2606cc Fuel Injected L4 Vin:G6
B3000 (1)
1994 3.0L 2999cc Fuel Injected V6 Vin:U
B4000 (1)
1994 4.0L 4016cc Fuel Injected V6 Vin:X
NAVAJO (4)
1991 4.0L 4016cc Fuel Injected V6 Vin:X
1992 4.0L 4016cc Fuel Injected V6 Vin:X
1993 4.0L 4016cc Fuel Injected V6 Vin:X
MERCURY (47)
COLONY PARK (5)
COUGAR (10)
COUGAR XR7 (7)
GRAND MARQUIS (10)
SABLE (15)
1986 3.0L 183cid Fuel Injected V6 Vin:U
1987 3.0L 183cid Fuel Injected V6 Vin:U
1988 3.0L 183cid Fuel Injected V6 Vin:U
1989 3.0L 183cid Fuel Injected V6 Vin:U
1990 3.0L 183cid Fuel Injected V6 Vin:U
PEUGEOT (40)
504 (4)
1980 2.3L 2304cc Diesel L4 Vin:XD2
1981 2.3L 2304cc Diesel L4 Vin:XD2
1982 2.3L 2304cc Diesel L4 Vin:XD2
1983 2.3L 2304cc Diesel L4 Vin:XD2
505 (25)
1980 2.0L 1971cc Fuel Injected L4 Vin:XN
1981 2.0L 1971cc Fuel Injected L4 Vin:XN
1981 2.3L 2304cc Diesel L4 Turbo Vin:XD2S
1982 2.0L 1971cc Fuel Injected L4 Vin:XN
1982 2.3L 2304cc Diesel L4 Turbo Vin:XD2S
1983 2.0L 1971cc Fuel Injected L4 Vin:XN
1983 2.3L 2304cc Diesel L4 Turbo Vin:XD2S
1984 2.0L 1971cc Fuel Injected L4 Vin:XN
1984 2.3L 2304cc Diesel L4 Turbo Vin:XD2S
1985 2.0L 1971cc Fuel Injected L4 Vin:XN
1985 2.2L 2155cc Fuel Injected L4 Turbo Vin:N9T
1985 2.2L 2165cc Fuel Injected L4 Vin:ZDJL
1985 2.3L 2304cc Diesel L4 Turbo Vin:4
1985 2.5L 2498cc Diesel L4 Turbo Vin:XD3T
1986 2.0L 1971cc Fuel Injected L4 Vin:XN
1986 2.2L 2155cc Fuel Injected L4 Turbo Vin:N9T
1986 2.5L 2498cc Diesel L4 Turbo Vin:XD3T
1987 2.0L 1971cc Fuel Injected L4 Vin:XN
1987 2.2L 2155cc Fuel Injected L4 Turbo Vin:N9T
1987 2.2L 2165cc Fuel Injected L4 Vin:XN
1987 2.5L 2498cc Diesel L4 Turbo Vin:XD3T
505 (CAN) (4)
1984 2.0L 1971cc Fuel Injected L4 Vin:1
1985 2.0L 1971cc Fuel Injected L4 Vin:1
1985 2.3L 2309cc Diesel L4 Turbo Vin:4
1986 2.2L 2155cc Fuel Injected L4 Turbo Vin:7
505 STI (1)
1987 2.8L 2849cc Fuel Injected V6 Vin:ZN3J
505 STX (1)
604 (4)
1980 2.8L 2839cc 2 Barrel V6 Vin:B3
604 (CAN) (1)
1981 2.8L 2849cc LPG/CARB V6
sorry could not resist putting all that in a quote. :shrug
whata ya gonna doo.
Practicing Infidel
I go with the biggest mofo battery I can find for the best price
I have no need for a fancy upside down battery. Right now I'm running a 6 year old Exide 875 CCA battery in one and the 1200 CCA "Total Battery" house brand in the other (which they happily replaced, completely free of charge, last Winter when it froze solid).
Far more important is the ground cables (as already mentioned) and a 3G 130 amp alternator upgrade. Buy a regular battery and save your money for the 3G alternator upgrade IMHO
Sixlitre
1 - 20 of 24 Posts
