Many bigger paint stores can add any paint to an aerosol can, oil or water base. We had one many years ago, but the tech was new and not real reliable back then. The machine is a couple thousand bucks, so most stores probably wont have one.Yo OX,
Some have a local automotive paint shop mix up
aerosol spray cans or cans.
The place I just had paint mixed for painting bronco has that ability. Not so much worried about the paint, as how to keep it off the chrome.Many bigger paint stores can add any paint to an aerosol can, oil or water base. We had one many years ago, but the tech was new and not real reliable back then. The machine is a couple thousand bucks, so most stores probably wont have one.
I'll give it a look, thanks for the heads up.There is also a product called liquid mask made by associated paint. Hang the emblems upside down on some cardboard and roll it on with a foam roller. Its used for painting around windows and such. It is a bit pricey though.
Nope. Took her to a show the other night. Otherwise, I'm done for now.Any progress? @OX1
Water based direct to metal. Its sticky as hell and durable. We have had it on the roofs of a local cellophane plant for nearing 10 years now. The air there is thick with acidic chemicals: sulfuric acid and the like. Though getting it in anything smaller than a quart is nigh impossible.So getting back on this. Going to order the XLT's and fix up the Bronco/Ranger's.
What kind of paint do we think will stick to "chrome"?
Thinking about something thick, but runny, and using a small eye dropper.
Might even just try POR-15, very thick paint but has a dismal track record
sticking to smooth surfaces.
