1 - 4 of 4 Posts
I perused some threads, couldnt find the right info.
According to my owners manual, relay 5 under the under-hood distribution box, controls my reverse lights, oxygen sensor heater, and something canadian.
But according to this diagram I found on another thread:
Its not used on F-150's.
What I am really asking is where is the feed for the power to the reverse switch? I have a functioning switch, I jumped the connector to see if that would activate it also, no luck. Bulbs are fine and i removed the trailer plug that was there....Im friggen stumped and I need reverse lights to pass inspection.
Yes, checked switch with a Multimeter, I am getting no power to the switch. Dead. kaput. Unless its a ground switch. I did get a solid 0 resistance on a ground check on one side and nothing on the other.
Protip: Dont follow the damn owners manual for crap. I found the correct fuse guide on Steve's supermotors, simple 15 amp fuse...:banghead
Idk why the discompare with what the manual says and the actual power layout.
1 - 4 of 4 Posts
