i was wondering if anyone has had a problem with a 79' bronco not having reverse lights when you need them and also when its in reverse it turns the brake lights off,if so i could use a few good tips
When it is put into reverse it cancels out the brake lights? Don't know how as those 2 are on a seperate circuit.
You probably need to adjust the neutral safety switch on the trans to get the reverse lights to work. Well that is if you have a C6. I would also bet money that only about 15% of the 78-79 Bronco's have functioning reverse lights, it is a common problem that goes wrong with them but very easy to fix.
yea thats what i figured it was,im just considering rewiring the whole truck and yea it has the c6 how complicated would it be to rewire it on a scale of 1-10?
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
