I want to wire in another reverse lights and was wondering if anyone here has done it and how they wired them. Pics are also appreciated:thumbup Thanks guys!
Cool thanks man I appreciate the quick response. Ill letcha know how it turns out.If its a round connector from ford read the cover it tells you what pin does what. I think its the top right though. Hook a line from that wire to #85 on the relay and a ground to #86. Then hook a hot (fused) to #30 on the relay. After hook pin #87 to the lights. Ground the lights and tada. It should work. To have an manual on switch hook the control wire from the switch to #85 on the relay.
Any way that I could use a power source other than the battery? thats just a ton of wire being ran under the truck.If it would be me I would use a hit from the battery to take off the load of the stock (old) wiring harness.
And the line to the connected would indeed act as the switch.
You only need to run one wire (+) hot to the relay under the truck; from there, you could mount the relay and run the rest of the wires from the back.Any way that I could use a power source other than the battery? thats just a ton of wire being ran under the truck.
yo,....So besides the easy stuff like cleaning the ground and making sure its not cracked how can I figure this out? I know it grounds to the frame on the driver side right behind the gas tank (right?). is there any other way I can test it?...
