I got my kit from the Bronco Graveyard....worked well, upgraded my distributor and alternator at the same time.
Good luck
I rewired my '79 Bronco using the American Autowire kit. No issues. If you have AC, let me know... their kit doesn't support factory AC vehicles, but I figured out how to adapt their harness and upgrade the electrical side of the factory HVAC too.
I am in the middle of doing a rewire. It feels like I am rewiring Fort Knox but that is my own doing. I am using the AA kit as well. It is pretty straight forward. The one suggestion I would add is running independant grounds from a bus block. The old wiring grounded everything locally and was prone to issues that usually go back to those local grounds. If you run independant wires from a ground block near the battery I believe you will see less problems.
