How Long Will the D44 last with 42" tires
  • It will explode when it touches the first rock it sees
    Votes: 7 17.5%
  • one good trip.
    Votes: 7 17.5%
  • two good trips.
    Votes: 8 20.0%
  • 1 year
    Votes: 10 25.0%
  • 2 years
    Votes: 1 2.5%
  • Longer
    Votes: 3 7.5%
  • Other.. Splain Lucy!!
    Votes: 4 10.0%
1 - 20 of 22 Posts
huh
1995 Bronco, Slightly Modified
Im bored.. Dont feel like working on the truck.. Got these in the mail today..
Thought the size difference was pretty interesting.. 1/2 ton vs 1 ton..
1/2 ton gears are d44 rr TeraLow Gears
1 ton gears are 10.25 Yukon Gears
both 5.13:1 ratio
Anyhoo, lets make this dumb post interesting.. Ill turn it into a poll.. How long till the 42"s destroy the d44..?
i can bring this up when the 44 lets go.. if it does..
plug ugly said:
two trips, maybe three. the way I see it, you will be kinda a puss the first trip (first time out and all since the rework) the second time you will start gettin it and the third time, wamo. Yeah definately the third time.
I just got my 60/10.25 gears also, 513. man they are huge and fawkin heavy
ya, mine keep trying to get delivered, but i am never home :banghead :banghead :banghead ow well, tomorow will be the last day they try to deliver it, then ill go pick then up.
I think over a year if you drive smart.
If you drive like jopes then 1 trip:goodfinge
Why dont you reinforce the axle like in the last issue of 4wheeler?
I know you may lose some ground clearence but if done correctly you will never crack the D44.
Since you have Warns/CTM's you dont have to worry bout those.
So I guess the only weak link would be the hub and bearings but those are cheap and easy to replace.
I dunno just my 2 cents.:shrug
FSB's Bastard Child
I think the fact that you have warns and ctms right off the bat is gonna help a good amount. 42 is a big tire to run on a 44, But as long as you are smart....And dont drive like Jopes :goodfinge :goodfinge :goodfinge , You should be ok for the time being.
Once you get a 60...Will it be almost a bolt in, Or will you need to do everything all over again?
1 - 20 of 22 Posts
