1 - 17 of 17 Posts
I am going to 4x4 shop tomorrow to have the mechanic, who is very well respected in 4x4's, try to diagnose my problem (transfer case/rearend.) I just want to put out there that when I let off the gas, and the roaring gets worse, my rpms drop with the sound of the roaring getting louder. Anyone want to put their 2 cents before I go???
Bob Labob
u-joints... that is my 2 cents...
Test this buy pushing down on the e-brake, put it in drive and then reverse and if there is a clunking noise most likely joints... But a bad u-joint will also vibrate at high speed when you let off the gas...
So if you have no issues when applying the gas and only have issues when costing or just get off the gas... Then I say u-joint...
Lick my balls
crown and or pinion
this is going to seem silly, but why do you guys call it an E-Brake? Isn't it a parking brake? Anyhow, if it is my rearend, is it best to just replace whatever is wrong in it, or start looking in junkyards. FYI. 3 weeks ago I pulled the rearend cover and it wasnt to bad looking. Not alot of metal at all. Just some mush on the drain plug magnet.
Bob Labob
Doesn't matter to me what it's called but I know since it is cable controlled I could use it to stop in an emergency if for some reason my hydraulic brake system went out...and I can also use it for parking on steep hills if needed
Bob Labob
How much do you like your truck? Not so much? Junkard. A lot? Get some parts and have someone rebuild your rear diff.
Where do you get the parts? Me. :beer
Designated Tranny Killer
Bob Labob
there shouldnt really be any metal shavings in there, that makes me think the pinion. Does it buck or vibrate at all?
Lick my balls
Did you remember to top up the fluid after checking it?
Hyul hyuk hyuk...
...seriously.... did you?
Hmmm, Roaring noise coming from the rear. Very simple to fix, rollup the back window and turn up the stereo.:thumbup
Satyr of the Midwest
1 - 17 of 17 Posts
