I'm not sure if I have a roller cam or not.Maybe some one can shed some light.FlSE is over my starter,if this is the correct spot.It's the only thing I can find with the starter on anyways.But my tag on the core support has F4TE on it,then my emmissions sticker on the hood has F4AE.I'm cofused!
OUT OF BUSINESS / M.I.A.
Do you know how to check your base timing?
If so the easy way to find out what cam you ahve is to pull the distributor and check the gear.
If thats the stock motor ya...you got a roller cam
As far as I know it is.I just thought I was going to see F4TE over the starter if was a roller cam.I read that somewhere.Guess I'll just have to pull it apart before I ever buy parts.
Thanks
Thanks
That was for the 5.8L. The 5.0 had them before the 5.8's did.
