1 - 4 of 4 Posts
Hi Folks,
I did a search, but couldn't find what I was looking for. I plan on removing the transmission ('86 302/AOD combo) to get it rebuilt. I've never removed a tranny before, so I've been studying the Haynes Manual and researching the threads on here. The Haynes Manual says to rotate the engine by means of putting a socket on the crankshaft pulley bolt in order to get to the torque converter bolts. However, it warns not to turn the engine "backwards". I'm not sure what that means. Does that mean that I should not rotate the crankshaft the opposite way? If so, how should I rotate it - clockwise or counterclockwise? I also checked the engine chapter in the Haynes Manual, but couldn't find anything on that.
Thanks for any info!
You're correct in your thinking... turning the engine backwards means turning it the opposite direction is was designed to run. You would rotate the engine clockwise, with a 1/2" ratchet or breaker bar
1 - 4 of 4 Posts
