1 - 12 of 12 Posts
Hi everyone,
I am replacing my pads, rotors and planned on doing the bearings and seals. I have taken everything out but cannot remove the hub from the rotor. There is a wheel looking thing that will not allow the hub and rotor to separate (picture). I hit the studs out, took the inner bearing and seal out but wheel thing will not budge. I tapped it a little from the opposite side, hoping it would come off but I did not. I searched here and YouTube but cannot find an answer, probably because I don't even know what it's called. How can I remove this and get the hub on my new rotor?
if Ford didn't want it reused, they shouldn't have discontinued it, lol
It's not hard to get off, I just recently did all this in the end of summer. Give your wheel studs some smacks until they are loose and resting on the tone ring, then go in a circular pattern around the studs giving them light hammer taps until it pops off. Alternatively, I know Advance Auto sells whole rotor/hub/ABS assemblies ready to install.
The tone ring is pretty soft, so you don't want to really smack it hard, I imagine the stated need to replace it is due to getting heavy-handed and smashing it off and thus cracking it, which will cause the sensor to not read it right.
There's a good tutorial on FSB about rotor removal with the tone ring. It is basically as described here using the studs to tap it off.
Check this post on my build thread
Brass drift and hammer - the studs will knock it right out. Am I reading your post right that you got the studs out but the tone rings is still there? I'm not seeing how you could even do that....am I missing something?
Thanks guys, it worked. I appreciate all the input and links of information. Now let's put this thing back together. I was going to change the bearings and seals but they look brand new, no cracks and discoloration. I think I'll just repack with grease and send them back to rockauto. The rotors and pads were very bad though so I'm glad I did this. Thanks again.
When you put the new rotor on, use the nuts and some spacers to ensure the rotor is pulled up tight against the hub shoulder. I had a machine shop press new studs in and I got excessive stud movement just torquing them to 90 ft-lbs.
If you’re anal like me and indicate your rotors, expect to be disappointed. I’d advise to just stick them on and go. I chased it for a week with the machine shop and I got from 0.011” to 0.006”.
With the studs, I used a punch pin to put them back in. Hit them as hard a I could and made sure they popped out the other side. I put new rotors and pads. When I tightened up the nuts on the wheel, I noticed I kept going and going. I assume because it was pulling the studs into place. I took it for a drive and everything felt good. An added bonus was this got rid of a squeak I had. I was hoping it was a bearing or the new pads a placed weren't working well with the old rotors. My dad thought it might be a u joint in driveshaft but luckily this did get rid of it.
I wouldn't reuse that tone ring, looks like some of the teeth are pretty mangled, that's just my .02 cents though. When i did this I was able to source the ring individually but now it looks like you have to buy it as a package, On Rock's site anyway.
Discussion Starter #11
They were actually in pretty good shape, just dirty. No teeth were messed up at all. I wasn't sure how to put it back on but I figured tap it in with a mallet. Seemed to work. I did notice my manual hubs are a little harder to turn from free to lock. I've never used it but they're definitely harder.
Just don't set the tone ring to deep or it will activate the abs. I usually just set it flush with the hub flange. I usually take a chunck of 2x6 and tap it on.
For future reference, an air hammer makes setting the lugs back in a breeze.
Sent from my Pixel 3a XL using Tapatalk
1 - 12 of 12 Posts
