1 - 11 of 11 Posts
Hi
My 89 Bronc has a new crate engine (302) and is running rough as well as smells like gasoline bad. I replaced the MAP and O2 sensors no luck. It also backfires in 3rd gear. Any suggestions?
Art
Texas
Look at your vacuum lines. See if anything is unplugged or leaking. Maybe even a gasket between parts. Raw air can really throw off sensors and they may be dumping too much gas in the intake.
Thanx
But like I said, its a brand new crate engine. Pressure tested and guaranteed. I think its a bad sensor, but I dont know alot.
I just had posted about my similar debacle, which ended up being an air intake temp sensor. The best purchase you will ever make is a code reader at your local auto zone for $29.99, but only after i threw a bunch of parts at it first with zero success. Coil, fuel pressure regulator, coolant temp sensor... then I got a code reader, which lead me right to the AIT semsor problem & it actually got me to solve a few other problems I didn't know I had. Now my Bronco is running better than it ever has. Mine also has a new crate motor in it. I bought the truck from the guy that put the crate motor in & didn't put any new efi sensors in anything, which was all it needed.
169430
This was my debacle thread.
I had a new sensor in there, so I figured it was good. After enough throwing parts at it, I got my meter out & measured the resistance between the pins of that AIT sensor & it showed open so it was bad... I still had my old one, which metered still good, showing 0.34ohms @the 200k setting.
A little $12 part was all it was.
1 - 11 of 11 Posts
