Well after finishing the passenger side replace spindle, brake caliper , wheel bearings and such and new mile marker hubs the driver side old warn hub doesn’t want to budge
I have pb blistered the shit out of it
What’s next ? Any tool will help?
Charlie don't surf..
'92 Ford Bronco XLT
1 o'clock in picture, looks like housing is bent in. Remove tire and get a better look.
Does look slightly bent, but those hub housings are pretty stout, looks like someone put a screwdriver or something in there..
There are only the two snap rings, the one at the end of the shaft and the larger ring on the hub housing..If you have both of those off it should come out..Over time hub bodies can almost get cemented to the inside of the housing..hit it with more PB blaster and keep working it back and forth it should eventually come out..
'92 Ford Bronco XLT
nice..that was pretty rusty..
