I have the saginaw van bracket and was looking at the saginaw power steering pump from a 2004 Chevy 2500, that seems others have used that did this conversion. It looks like the return tubes on the pump will hit the power steering pump/ac bracket. Did you have to cut them off and reposition. Can someone who has done this please give me some coaching. Is there a different pump that I should use?
Discussion Starter · #2 ·
as a follow up to this, I want a dual return pump so was trying to avoid a T in the return line. Just trying to understand the fit of this pump with the Van bracket I have for a safinaw pump
This is the pump I used on a fox body 302, but same style van bracket. I can dig around in my receipts to see what it came out of.
Addicted to Junk
If you must cut them, get some hardline-to-AN adapters and run them. Not many vehicles came with a Type 1 sag and Hydroboost. Some astro vans maybe. You might look at a Type II sag with remote reservoir.
