1 - 16 of 16 Posts
ok so i'm doing the sag swap into my 90 bko (302) i'm swapping from a van. I ran into quite a problem though, I have the pump, the pulley and the lines, but I cant find the bracket anywhere! I've checked the junkyards in 3 counties but nobody seems to have the ps bracket, if anyone has one or knows where i can get one, please let me know!
Administrator
2012 Jeep JKU
how soon do you need it?....I can check the local junkyards over the weekend for you...need info...what size motor and does the a/c compressor take the large or small bolts?
If you can get it for me, anytime that is conveinent for you. I have a 302 with 10mm bolts, so if you can get one for that, but i dont mind having to drill the ac holes.
Administrator
2012 Jeep JKU
ok i will check the yards on sunday (planned on going anyways) If i find one I will grab it....iirc the mounts are the same for the 351 and 302.
Man i'm telling ya, you would be my savior if you found one, I mean I dont know if its just this part os the u.s. but I cant find econolines anywhere
Any update on sourcing a bracket? I am in the market for an E-series pump/pulley/bracket for a conversion. I don't care what size the A/C bolt is on the bracket as I can drill out the compressor if necessary. I would like to get a complete "system" with hardware if possible. I'd kindly pay a finders fee too ;)
Discussion Starter · #11 ·
well I sent a pm to those who said they have them with no response, so I just gotta wait I guess.
Discussion Starter · #12 ·
Gonna be $77 + delivery but Countryside Ford has a couple in stock, or did middle of last week. Call (330) 879-2124. Ask for Part #F4UZ3C511A Good luck--Buzz
I called, and he said he couldnt get one or knew of anyone that could get one, but it was worth a shot. :thumbup
napa has a sag. pump that will bolt in all you have to find is the power steering bracket from a 80-88 I believe here is the link thats shows the bracket.
http://www.broncohio.com/tech/napapump.html
I'm NW of Houston where there are plenty of salvage yards. If you can give me a picture or better description of what you need I'll hit up the ones around here.
1 - 16 of 16 Posts
