1 - 9 of 9 Posts
Parting out my 89 bronco crawler, body and frame are gone, have below list of parts left. Everything was running fine when I pulled them, all parts located in San Diego, CA, will not ship.
-Engine, 351W (lower intake to oil pan) alos comes with all accessory brackets, good rebuild core. I built this as a stock build when i installed it to pass smog, has speed density friendly cam. 250.00 obo
-Trans, AOD, good core 150.00 obo
-Xfer, Manual shift BW1356 150.00 obo
-KluneV David 1-2.7 underdrive, I bought this new, never used only mated up once then put in box. 1000.00 pretty Firm
-Ford NP205 xfer case complete 250.00 obo-SOLD
-Set of 4 39.5 IROC Bias tires on recenter hummer rims, 3.5 inch back space, 8 on 6.5 lug with pvc inserts for double bead lock, minor rock rash, tires have 75% tread left 600.00 obo - SOLD
PM me or email me at [email protected] for pics
Yo da_offroadnut,
Post pics ASAP. Good luck!
The KluneV fits standard ford six bolt pattern, it bolted between AOD and ford NP205 which i believe is same pattern.
If you weren't acrossed the country I'd be all over those tires and rims. If you change your mind on shipping, I can get a quote to get them shipped through Fastenal.
1 - 9 of 9 Posts
