1 - 13 of 13 Posts
I'm gonna do a SAS on my Centurion. Has anyone done a SAS and used Superrunner steering? When I sas'd my '85 I just had to mount my track bar at the same angle as the draglink. How to I get the right angle on my track bar w/ superrunner steering? Anyone done this? Got a pic? Thanks
It wouldn't work. Whenever you hit a bump or compress the front springs it sgoing to point the tires out.
Anybody want to buy a Superrunner steering set up????? Also ttb drop brackets cheap
Discussion Starter · #8 ·
stangmata50l said:
Didn't you JUST lift that thing?
What is a superrunner steering setup?
The only thing I'm not using from the ttb lift is the axle drop brackets, so not much money was wasted on that stuff. Superrunner steering uses an idler arm instead of an inverted y set up like stock.
FSB warrior
Obviously he should donate some more of that $$ to this site....;) Must be nice
Engineer
I thought you were going to leave it stock... then i thought you were going to leave it lifted and now you're doing a SAS
inchitis, they say it spreads over the internet
They call me "MR FLAT TIRE"
there is a semi-affective treatment for that.....
Gaspricis. it works as an inchitis inhibitor by blocking tempted funds.
1 - 13 of 13 Posts
