1 - 18 of 18 Posts
No prepuce on my -
Whoa....freaky....
Formerly vt89gtvert
Kinda cool, but I was hoping you had a cool "mythbusters trick." One of the coolest things I have ever seen was when a Community college proffesor mixed Iron Oxide with Aluminum (I think that was it but not entirely sure). Did it in a cambels soup can and it burned through a 1/2 inch plate of steel in NO TIME. Then into a 55 gallon barrel of sand which it also heated to a glassy like substance. That was really cool
Lick my balls
That is scary.
vt89gtvert, I am very sure you got that wrong. The slag from burning steel with a torch is basically iron oxide and I have had that in concact with aluminum with no ill results.
Seeking Tanelorn
Still a long way to go. They still need to be able to construct the cell with all it's components before implanting the nucleus; then it's a completely artificial life form.
Zombie Hunter
Black Iron Oxide and Aluminum, both in dried powdered form, with a glycerin additive and some other trace amount additives.
and you have to do a couple other things in order for it to actually work.
It probably ripped right through the Campbell's can and slowed down for the steel.
green ones make me horny
hooray for Armageddon
1996 Bronco 5.0/E4OD/BW1356
was it thurmite?
Yes - what they are describing is thermite. Thermite is simply iron oxide (rust) and aluminum shavings. Combine these two and ignite them with some magnesium and you will create a substance so hot it will burn through most things before you know it - including fire-proof blocks...
COOL! They should make halloween costumes, tents, couches, drapes, and winter hats out of that stuff! :rockon
1 - 18 of 18 Posts
