1 - 11 of 11 Posts
Previous owner at one time removed the top and then put it back on and only bolted one of the rear three point seat belts back to the roof. Other bolt is missing now. Does anyone have a clue on the sizing or where I could find one? None of the usual bronco sites seems to carry it. There are no junkyards around me otherwise I would simply run into an F150 with a socket set and take one.
Discussion Starter #2
Right, okay, should have known I'd get that answer. More specifically do you know Ford's part number for that bolt? I haven't seen a parts diagram that shows it and lists it as well.
In the middle of a field the size of Vermont in South Dakota.
I did done broke it
Take the bolt out and go to a hardware store. Problem solved.
I did done broke it
Just make sure to get grade 5 or 8. All the hardware stores by me have them. Or go to Fastenal or something if you really want
I did done broke it
You know what I meant. Ask the strongest friggen bolt they have and you'll be fine
1 - 11 of 11 Posts
