Ok i am trying to strip the carpet out of the interior of my 94 F-150 EXT cab. I got the passenger seat out no problem and my center console. I can't break any of the 4 bolts on the driver's seat loose. I have tried a breaker bar with a piece of pipe and an air ratchet. I have soaked all of my bolts with PB blaster numerous times. The 4 nuts on the back seat are turning to dust and i can't break them either. What is the best way to break any of these 8 bolts loose? I really need to get them out so i can paint with Rust Bullet. The rust is getting unbearable to me!
Along with those 8 bolts i can't break the driver side seat belt loose either. I bent one torx today trying.
-Curtis-
Discussion Starter · #2 ·
Ok i rung the heads off the two front 15mm bolts. Now i have to worry about getting the nuts off the studs in the back of the bracket.
-Curtis-
If it doesn't break loose, the stud will unscrew from the floor with the nut intact............or you'll snap the stud and get more practice using a drill and an ez-out:thumbup
Yeah if all 4 get rung off ill replace with stainless bolts and nuts. The back nuts are worrying me. Im going to try heating them! But i have to wait till friday afternoon to fool with the rear bolts cause if they break i need to be able to drive to school everyday.
Should i try using a right hand drill bit and try screwing them through or should i go right to the easy out on the 2 that have snapped?
-Curtis-
Not too safe driving with no front bolts to hold the driver's seat:smilie_slap...pull out from a stop a little too hard and you're in the back seat
Yeah i know, i am going to have to be careful thats for sure!
-Curtis-
