1 - 4 of 4 Posts
Any tips or tricks to removing the seat cover. Specifically the bottom, I have a seam that would be easier to sew off the seat base. I have a cloth bench seat with the lumbar pillows.
TIA.
yo
This is for the 96 from F_ _ D
Seat Back Cushion and Upper Frame, Seat Back with Armrest
Removal
Remove seat from vehicle. Refer to Seat, Driver and/or Passenger, Bench in the Removal and Installation portion of this section.
Unpin the five (5) retaining pins on the back of the front seat trim panel using a flathead screwdriver. Remove front seat trim panel.
Cut the seven (7) hog rings retaining the front seat to the front seat back bolster wire.
Cut the two (2) hog rings retaining the seat cover to the seat back frame.
Unclip J-clips attaching the front seat back cover (64416) to the front seat cushion frame and spring (63100).
Cut the 12 hog rings retaining the front seat back cover to the front seat wire.
Remove front seat back cover.
Installation
Follow the removal procedures in reverse order.
Seat Back Armrest with Cover
Item Part Number Description
1 64416 Front Seat Back Cover
2 6365446-A Wire
3 Hog Rings
(Part of 64416)
4 5465446 Wire
5 61018 Front Seat Back Frame
6 644A18 Front Seat Back Center Armrest
7 N802735-S2 Screw
8 Tab (Part of 644A18)
9 654A98 Armrest Check Assembly
10 63076 Front Seat Center Armrest Bracket
11 64810 Seat Back Pad
A 3 Req'd Each Side
B 1 Req'd Each Side
C Seven Required
D Routing of Cable Must Be As Shown
Thank you guys.
How do the 2 mounts for the cupholder and controls for the lumbar fit in there? Do I have to remove those?
yo,
On da Pump, Front Seat Back Pad Adjusting
Removal
Remove seat support bolt insulator and seat assembly from vehicle.
Remove front seat tracks (61704) from front seat cushion frame and spring (63100).
Remove front seat cushion cover (62900) as necessary to gain access to front seat back pad adjusting pump screws.
Remove mounting screws, disconnect front seat back pad adjusting hose (65528) and electrical connector and remove front seat back pad adjusting pump (65530).
Installation; Follow removal procedures in reverse order.
see diagram r8593b
1 65530 Front Seat Back Pad Adjusting Pump
2 14B722 Seat Back Control Switch (RH)
3 14C723 Seat Back Control Switch (LH)
4 Electrical Switch Connectorm (Part of 14401)
5 65528 Front Seat Back Pad Adjusting Hose
6 14C713 Seat Back Control Switch Bezel
7 N610130-S58 Screw(s) (2 Req'd)
8 63100 Front Seat Cushion Frame and Spring
Pad Adjuster, Front Seat Back
Removal
Remove front seat (60012) and front seat tracks (61704) as described in Seat Assembly, 40/20/40 Bench in the Removal and Installation portion of this section. Place the seat on a clean surface.
Remove front seat back cover (64416) as described in Seat Cushion Cover and/or Pad in the Removal and Installation portion of this section.
Disconnect front seat back pad adjusting hose (65528).
Using a screwdriver, push the 4 plastic pushpins out of the front seat back frame.
Remove front seat back pad adjuster (65500) from front seat back frame (61018).
Installation
Position front seat back pad adjuster to front seat back frame. Return the 4 plastic pushpins to their original holes in the front seat back pad adjuster.
Connect front seat back pad adjusting hose to front seat back pad adjuster.
Install front seat back cover as described in Seat Cushion Cover and/or Pad, Bench Seat in the Removal and Installation portion of this section.
Install the front seat and front seat tracks into vehicle as described in Seat Assembly, 40/20/40, Bench in the Removal and Installation portion of this section.
Check the front seat tracks and front seat back pad adjuster for proper operation.
see diagram r11283a
1 61018 Front Seat Back Frame
2 65500 Front Seat Back Pad Adjuster
1 - 4 of 4 Posts
