IM FAT, YOUR UGLY!
F*ck 'em all
don't know if this is what you are asking, but i figured it couldn't hurt.
Motorcraft Premium Synthetic Blend motor oils
are manufactured with high-viscosity index,
premium-quality, synthetic / hydroprocessed base
oils and specially designed performance
additives, which help minimize engine deposits
and wear, protect against high-temperature
oxidation, low-temperature gelling, rust, corrosion
and foaming.
Motorcraft® Premium Synthetic Blends
Premium Quality Passenger Car Motor Oils
Features
 Designed, Engineered and Recommended by
Ford
 API Certified for ILSAC GF-4 (designated by
the Starbust symbol on the front of the label)
 Enhanced Oxidation and Thermal Stability
 Improved Low Temperature Pumpability
 Base Oil Formulated with hydroprocessed /
synthetic base stocks
Satyr of the Midwest
I've always looked at it like this: it could have 5% synthetic oil, and they'd still call it semi-synthetic. Something worth doing is worth overdoing, so why not pony up a few more dollars for the full monty? Hell, it's very cheap at Wally World and you can go 7500 miles between changes.
IM FAT, YOUR UGLY!
I already use autozone branded 10-40 I was basically asking what semi synthetic was, is it just regular oil with a some amount of synthetic in the blend?
penis
Yes they are also called synthetic blend. Your cheap oil is around 5% synthetic oil while higher blended oil are around 70-85% Sythetic oil. Depends on what you perfer is all. Different companies also have different percent of conventional to synthetic ratios. High end companies are usually around your 70-85% sythetic ratios while the cheap oil has around a 5-10% ratio.
