1 - 11 of 11 Posts
Who needs oil anyways....
Any recommendations on how to seperate the muffle from the inlet pipe? They aren't welded, just really tight and slightly rusty. Clamp was cut off.
Hmm, guess it's time to invest in a rubber mallet..... :thumbup
heat it with a torch and it will slip rite off
if you dont have a torch cut a slit, one on each side with a die grinder or dremel with a cut-off wheel
if you dont have one of these, your on your own
Discussion Starter · #8 ·
Thanks for all the tips. I'll try them all in random order until one works. :thumbup
You can borrow a tailpipe cutter from Auto Zone. Or check your local parts store for a loan-a-tool program.
1 - 11 of 11 Posts
