1 - 13 of 13 Posts
TIME TO GIVE BACK.
I have gotten a lot of help from people with access to service manuals over the years. I couldn't have done half the stuff to my Bronco without people who cared enough to post diagrams and technical writeups of repairs, maintenance, etc. Now that I've got my own manuals, I want to pay it forward so that others can succeed the way I have. The following links are to a pair of Google Docs folders that have PDFs of all the sections for the 1995 Service Manuals. I chopped them into smaller pieces so that you can more easily find the info you're looking for, since the chapters/groups are pretty dense and it's sometimes hard to track down the exact thing you're looking for. Yes, it's only the 1995 manuals, but they should work for almost everything 1992-1996 and get you in the right ballpark for most things 1980-1991. Happy wrenching! :thumbup
1995 Drivetrain, Powertrain Service Manual
https://drive.google.com/open?id=1M0M9m9vtiOxwy5wkJ203tlSTjwuWzcew
1995 Body, Chassis Service Manual
https://drive.google.com/open?id=1MJ0Li_e-Esufa-pnSR-edaQ9VD15SiMS
(to switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window)
Wow! Where were you 2 years ago when I spent all the money and time getting a decent set of these off eBay. I'm sure it took a good bit of time and at least some talent to compile the collection as you have. Bravo Sir and even though I don't need them anymore, that's an outstanding contribution to the site and Bronco enthusiasts everywhere. :thumbup
Have you got the EVTM in there somewhere too?
You're in luck (after the fact!) - I found a Google Docs link on here that someone had posted for a file that contains both Service Manuals, EVTM, & PC/ED manual for all Fords 1992-1996. And I wish *I'd* found it before my last birthday when my wife bought me a hardcopy PC/ED off eBay :banghead
The file is an ISO that takes an external program to mount to your PC. It's not a straightforward process and I only figured it out through trial and error. BUT it's been handy since it's indexed better than the hard copy for troubleshooting since it has links to take you to the next step once you finish the one you're on. The diagram images are a little less clear than the originals, but still better if you're working with a fat lot of nothing. I'll try and track it down and boost it here so other people can get the goodies, at least for 92-96 rigs.
Okay, that was a quick search. I had forgotten that Kingfish999 gave me the link as recently as August 2019. Here's the text from his reply to my request for PC/ED files:
"i have the 92-96 and 96-99 programs (which are seperate programs) on my google drive account. there in ISO format if you know how to use them, you can either burn them to a DVD or mount them virtually to install. theres a video for installing them. also have 88 and 90 in PDF format. even have 00-04, 05-06, and 07-08 which are all the same program as the 96-99. but the last 2 require changing the computers date in order to use. these inclued EVTMs, Service Manuals, PC/ED, and some include others
https://drive.google.com/drive/u/0/f...dtCaT4u7iRTB3w
https://drive.google.com/drive/u/1/f...hg3qVe2vnMjHJU
if anyone has any other the other years in PDF they are willing to upload to my drive, you should be able to upload them here. alot of people cant use the programs so the PDF versions are good to have
https://drive.google.com/drive/u/1/f...ZrxGD0q0T-7n38"
So there you go - lots of manuals to be had. If you need some tips on how to make the ISO work, PM or reply and I'll help as I'm able. And if I can't, Kingfish999 made the things and can probably assist where I fall short. Off to add my files to his collection...
Oof. That's what I get for not checking the links: his three Google Docs pages are not working as of 0745 16 Oct 2019.
Well, lemme know if you need documents. If my Google gets shut down too, PM me.
Man of endless projects
the links are still good. its because the forum automatically shortened the links in the original post so when you copied and pasted the text, it was incomplete.
do you mind if i add yours to my collection? people prefer PDF that can be viewd from any smart deevice over standalone programs requiring Windows
https://drive.google.com/drive/u/0/folders/0BzRTW4yeT2u4NXB6NW5neFRoZGc?fbclid=IwAR3yC0aAvexy888R7-GnNWbEPBRq9J1IDt1ASX942OS3_dtCaT4u7iRTB3w
https://drive.google.com/drive/u/1/folders/1w2Y_-jPnglO2wgewhA1TMYf3QCZS3o2i?fbclid=IwAR0McjP4BY6TzhvgZxxEtk4kkgT5DMpsBKrgdZmKt3DcPhg3qVe2vnMjHJU
https://drive.google.com/drive/u/1/folders/17Kt-keCfIXqibtU1AF_miIa8cKZfBkT6?fbclid=IwAR1pdWi4bmQEGfk0A_NdYGBnwpQSr0Dgo3VcDOc8fATAzZrxGD0q0T-7n38
Razor, your CD should include a PDF for it. might be labeled differently. both my 90 and 88 did
(y) Oh thank goodness! You have so many documents on there that it would be the shame of the world if they disappeared. Yes, feel free to add the PDFs from my page. My next project is scanning my hardcopy EVTM and PC/ED manuals and converting them to PDF, so I'll post again to this thread as they're available on my Google Drive page.
Discussion Starter #12
Thank you so much, folks!!
I downloaded that ISO but when I tell it to pull up the 1994 Bronco, it asks me to insert the CD?
I think I had the same issue at first. I went back and downloaded the disk manager program the OP suggested (DAEMON Tools Lite 10.11) and used it to mount the ISO and now it works like voodoo magic.
there should be a video in there that i explain how to set it up correctly. after you install the program and then extract the files of the ISO to the hard drive, and change a parameter in a settings file, you dont need daemon tools anymore. right sounds complicated but its really not bad.
the problem is this old program isnt really programmed right. it works for a standard install for a ford tech, but has some issues when doing a custom install
1 - 13 of 13 Posts
