I have read on here a few times that when doing a shackle flip, to rotate the springs 180 to help with getting the wheels re centered in the fender. So, the spring length is 56" long. From front eye to the pack bolt is 24.5". From rear eye to the pack bolt is 31.5". That's 7" difference.
So if I rotate them, my axle be moved back 7"? Subtract 1-1.5" from the lift and you still get 5.5-6" moved back. What am I not seeing?
OMF
Rotating the springs would screw up the pinion angle in a major way.
Either relocate the front spring hangers or use an ORD Zero Rate Add a Lead to re-center the axle.
Well, I wound up just moving the front hanger back 1". I moved the rear forward 2" and down 1". Is now sitting 5" higher from axle center to bottom of fender than the front.
Discussion Starter #5 (Edited)
A new front hanger. My reference forints for forward and down are based on the bolt hole on the spring hanger. I even ordered the ones with 6 bolts as opposed to 4. Just to cut the top 2 off and wind up welding it on.
