1 - 13 of 13 Posts
for those whom have leaf springs with shackles in the rear, did you have to alter your drive shafts?
that link doesnt work
G
Hmm., that link sent me to microsoft.
Look up at the address in the bar and drop in the 66245 where the 5 digits are now. I will see whats up with the linking.
badass1tonf100 said:
there is a thread that already address' this topic
{URL="http://http://fullsizebronco.com/forum/showthread.php?t=66245"}http://fullsizebronco.com/forum/showthread.php?t=66245{/URL}
{URL="http://fullsizebronco.com/forum/showthread.php?t=66245"}http://fullsizebronco.com/forum/showthread.php?t=66245{/URL}
try that maybe it will work
You had an extra http://
Never change the quotes, you want to change the bottom link if anything. Quotes are needed incase there are spaces in the link. Remember kids, when naming pictures or web pages, always user the underscore! _ :thumbup
it worked the second time around :goodfinge
Discussion Starter · #9 ·
so as i asked before, has anyone been forced to alter their shafts?
rofl
i know lots of ppl have rear shackles, has everyone using rear shackles bought a long travel shaft? if not what have you experienced does you d/s come apart or has it come apart
One Cold North Dakotan
You shouldn't have to change your driveshaft if you just lift it straight up, obviously. It would be no different than doing a coil lift. I guess just make sure you're measuring correctly, and if you have to move the axle at all, move it rearward to account for the extra distance the shaft has to reach. Just restating what I'm sure you know..
rofl
Yes. I had to lengthen the splines 1.5".
There are two factors for the shaft being to short; when doing the SAS, most folk will move the axle forward 1"-2", and the live axle allows for more droop.
negative creep
also, running the shackles to the rear of the spring means that is the end of the spring that is moving and your pinion will drop more. i never had an issue running stiffy f350 springs but with the 52" chevy springs i had to make a long travel (square tube) for now.
1 - 13 of 13 Posts
