1 - 1 of 1 Posts
1987 Bronco Eddie Bauer 5.0 with AOD
So I bought a 1989 bronco that had a 1995 5.8 maf motor swapped into it. It’s is run by the WAY1 eec. It was not running well so I tested the tps and it was bad. Replaced it and now motor runs great. Went to test drive it and it won’t shift into second in drive. It will manually. I pulled codes and found only one now, a 622 code. I checked the eec and it looks good. Check the wiring and all seem to be fine and have continuity from solenoid plug to computer. I went ahead and pulled the transmission pan to replace the solenoid pack. I went to look up what pack to buy to replace it and was a little confused with all the pwm or non-pwm and different types. I am wanting to “upgrade” it to the new style solenoid pack and so I don’t have a part number. Does anyone know which would work with my set up?
1 - 1 of 1 Posts
