1 - 9 of 9 Posts
I have a 94 bronco with a E4od and it will only shift to second gear. If i shift manually from second into drive then it will sometimes catch 3rd. But when its just in drive it wont shift past second. If anybody has any suggestions how to fix this problem i would really appreciate it.
Pull codes.
Is your tranny fluid at the correct level? Have you inspected all the hoses and lines coming to and from your tranny?
Pull codes.
yeah i just filled the tranny it was a little low, and ill check all the lines tonight. the wierd thing is though i can get it to catch third if i shift manually from 2 to drive but when its just in drive it wont go past second
I'm stuck :)
mine 87 wont shift outta 2 unless ur at or above 2000rpm and you let go of the gas pedal...
Satyr of the Midwest
No. In fact, transmission codes rarely, if ever, turn the MIL on.
Search a little, and you'll find the method to pull codes with a paper clip.
Probably because your 87's AOD TV cable needs to be adjusted, and your 87's AOD is nothing like his computer controlled E4OD.
1 - 9 of 9 Posts
