Ok, be gentle on me here :D
I'm in the process of "building" a trail rig out of my f150. It's gonna be off-road only...not driven on the street AT ALL. I've got a lift for it, but i'm gonna have to purchase shocks and i'd really rather spend that $$$ on other parts for the rig. Do I HAVE to run shocks on it?? I mean, won't i get better articulation w/o them? Will I get excessive axle wrap if i don't have shocks on the rear?
Thanks guys :thumbup
OUT OF BUSINESS / M.I.A.
I Think you need them.
For starters shocks don't stop axle wrap enough for it to be a factor.
If you wheel it hard in any situtiation you'll want shocks.
Mud pit: you might get some air if you make it out the end with some speed.
Sand: always need shocks
Rocks: if you wheel it like a baby then you might be able to get away without. But everytime you drop off a rock or take a trail a tad to fast it will get bouncy. bouncy might lean to a roll over if you are really speeding around the rocks.
negative creep
most of the time, shocks are the limiting factor in your suspension travel, unless you have limiting straps. if you weren't running shocks, i am guessing that you would run into problems with binding lots of things like your u joints and your springs. follow me?
