1 - 17 of 17 Posts
ate lug
88 + 96 broncos, 96 F250
Yeah, they used to be 2 keys. Based upon the trucks ive driven, it seems that they went to a one key system with the body change in '92.
Gamble Til We Die
i could make it work for you. come on down to ace hardware and ill cut it.
Broncobob- That's the style key that is commonly found on Ford gloveboxes and some Bronco tailgates. The standard Ford door key has a square head and has the blades of the keys switched from what is pictured.
OMG IT RUNS
Discussion Starter · #8 ·
Why would you want a Silver Anniversary key for a 94? And will the rounded end fit in the ignition?
Yeah i have a 95, w/2 keys one shaped like that for the rear window/glovebox and one square one for the ignition.
I think the newer keys have an extra cut in them.The Anniversary Key might not work.Depending on year
Won't work...The milling of the key is different, opposite of the ign key. Also the 92-96 keys are 5 cuts longer then older keys. The only thing that the key will work for on a Ford 92-96 is the glove box, center console or tailgate (*maybe*) The key will work for 91 and older as a door key.
I have the Silver anniversary keys (Door and Ignition) uncut. I can take a pic a post it so you can see if they have the cut or not.
1 - 17 of 17 Posts
