I have a 91 XLT5.8 litter and it has issues a-- lot of issues I bought it from a mother and daughter that just got tired of fixing it. My issues are running super rich lack of power and high idle I originally changed the egr from top to bottom the idle control valve map pcv some of the vacuum lines managed to get all codes fixed no more check engine light but it's just going to foul Everything again if I can't get air fuel mix to optimum not to mention$6.75 a gallon for gas! And then I had to swap rear end due to catastrophic failure I thought I got lucky when I checked the door tag they should have matched but they seemed to be off just a hair ..so now I need to find a way to make my rear drive shaft longer or possibly swap the flanged yoke on the transfer case to a slip in cause that's what came with the rear end from the diner truck my flanged shaft is too short it's trying to pull the seals from both sides out . Help if you have ideas or know of a way to get the only vehicle I have I can use for work and my kids!
