Greetings all! After 29 years in the family it's time to move on, so my 94 Bronco is up for sale. It's listed on AutoTrader currently, but I wanted to offer it up here as well. I'll paste that ad info here, but I'm happy to answer any questions. I have invoices for the most recent work that was done (nearly $5k spent).
Electric Red Clearcoat Metallic
Opal Grey interior
Single Family truck, purchased by owners father in 1994 at Bennett Ford in Chester, Virginia.
131400 miles currently
Modifications:
4-inch Superlift suspension lift with full leaf spring in the rear (not a lift block)
15x10-inch American Racing AR172 wheels in satin black with 33x12.50-inch BF Goodrich All Terrain K02
Flowmaster Series 40 Delta Flow muffler with new tail pipe
3G 130 amp alternator
Upgraded power steering with saginaw pump, Ford factory bracket, and new lines/hoses
Remote transmission filter
AutoMeter volt gauge installed
Desolate Motorsports dash brace bracket
All fuel hardlines replaced with nylon lines and quick release fittings
Known flaws
Normal wear on interior, carpets and body. Crack in the dash.
Body rust on lower tailgate, passenger side rear fender, some corrosion on side mirror brackets. Surface corrosion on underbody components.
Small oil leak (rear main seal)
Lock buttons and cruise control not working
Airbag light is illuminated
A/C system not currently charged
Side trim/moulding was trimmed for previously installed fender flares
Occasionally stalls when shifted into reverse (fluid level is ok)
Recent Service History
New distributor cap, rotor, spark plugs and wires – Feb 2023
Oil and filter change, new coolant – Feb 2023
New muffler and exhaust pipe installed - Feb 2023
New fuel tank, pump, fuel filter, sending unit, tanks straps, skid plate, and all hardware, seals/gaskets, filler hose, cap installed - Jan 2023
Fuel injectors cleaned/rebuilt (6), two brand new injectors installed – Jan 2023
Power steering fluid replaced, new high pressure hose installed - Nov 2022
Front core support replaced along with all hardware, core support mounts, A/C condenser, radiator, water pump, thermostat, coolant hoses, hood latch, headlight lenses and bulbs – March 2020
Entire transmission cooling system replaced – new lines, fittings, radiator, fluid, along with an added remote transmission filter. Installed new transmission pan with drain plug, gasket, and in-pan filter – Mar 2020
Wheel and tires installed in Nov 2017, driven less then 1000 miles since
Other items included in sale
Two sets of keys
Original owners manual and associated documents
Recent service records and part receipts
Original retractable trunk cover and cargo net
Extra parts – oil, oil filters, trans fluid, extra lug nuts
Full size matching spare tire and wheel
Two tow hooks for front bumper
Haynes Repair Manual
Factory AM/FM radio (no radio currently installed)
Opal Grey interior
- Factory equipment includes automatic locking front hubs (electric touch 4x4), chrome bumpers, a swing-out spare tire carrier, bucket front seats with electric lumbar adjustment, a folding rear bench seat, power windows and locks, cruise control, cargo cover/net, towing package, and air conditioning
- Power comes from a Windsor 5.8-liter V8 engine, rated at 210 horsepower and 325 lb-ft of torque. Output is sent to the rear or all four wheels via a 4-speed automatic transmission.
Modifications:
Known flaws
Two sets of keys
