1 - 3 of 3 Posts
So here it is, I have a 1989 Ford Bronco Eddie Bauer edition and when I turn the key on all the dash lights come on. The thing is is once I try to turn it over there is a single click from the solenoid and then all power is lost. I have to disconnect the pos cable from the battery and reconnect it to even receive power again. Got a new battery and tested the solenoid, what could be the problem keeping the Bronco from starting?
Thanks in advance!
Yo WFre801,
Welcome!
Here is the 1989 EVTM, Emissions & Pre-Delivery Manuals, Partial via mrnewland1 in Google Drive Slow scrolling. Find page # of item desired in contents, then flip screen flip down like spinning a bearing (a no-no) then stopping periodically to see which page you're on.
I believe it has ano crank TROUBLESHOOTING procedure with wiring diagram.
https://drive.google.com/drive/mobile/folders/0Bz1eScc6s4raOHd0WlVnMUw4WjQ?usp=drive_web
Battery that is fully charged produces 12.6 volts at rest with engine off and all lights and accessories off.
Inspect the terminals for loose or corroded connections.
Are battery connections including grounds to frame, intake manifold etc., clean and tight?
STARTER RELAY GROUND; Check for continuity between relay mounting bracket and clean chassis ground. Rust, grime, paint etc interferes with relay contrul circuit.
Pull red/light blue wire push-on connector off of the inner fender starter relay.
Relay pic in an 89 5.8 by Handy_andy_cv64 (Ed B) at http://www.supermotors.net/getfile/805835/fullsize/89broncostrtrelay.jpeg
With key in start position, should have batty voltage at red/light blue wire. If not, check for voltage at re/light blue wire on Neutral Safety Switch (also referred to as Back-Up Switch), then at ignition switch.
No voltage there in the "start" mode and you have a problem in the wiring, ignition switch, or neutral safety switch.
When you turn the key to "RUN/START" and there's no spring resistance feeling it usually because the actuator inside steering column is broken or ignition switch is loose.
Overview; "...The ignition rod is attached the upper ignition actuator by a 3/32 x 38 roll pin ($0.12 each) and the rod needs to be straight so it travels enough to trigger the igniton switch but it's a chore to take it off as you need to remove the steering wheel and tear it down to the (Tilt or Non-Tilt) knuckle, usually down when you replace a broken upper ignition actuator. The ignition switch located on the lower part of the steering column has slots so it can be adjusted by loosening the 2 -7/16 nuts and move it up or down but a lot depends on what's wrong up top with some of the other parts, ie: ignition rod, key cylinder, lower igniton actuator and upper igniton actuator. These parts are timed so when you turn the key to RUN they all need to move forward/downward so the rod triggers the igniton switch to START the BKO..."
Accessories that fail to operate with the key in RUN, or that remain on when the key is turned off, may be the result of a misadjusted ignition switch rather than a malfunctioning ignition switch.
Test the ignition system mechanical operation by rotating the ignition switch lock cylinder through all positions of the ignition switch. The movement should feel smooth with no sticking or binding. The ignition system should return from the START position back to the ON position without assistance (spring return). If sticking or binding is encountered, check for the following:
burrs on the ignition switch lock cylinder
binding ignition switch lock cylinder
shroud rubbing against ignition switch lock cylinder
burrs or foreign material around the rack-and-pinion actuator in the housing of the ignition switch lock cylinder
insufficient lube on actuator
Ignition Switch Pin-Out Diagram & Continuity Testing (Logic Tables) in 87-91 @ https://www.fullsizebronco.com/forum/21-noobie-bronco-tech-questions-flame-free-zone/455313-started-just-fine-aaahhhhh-wont-turn-off.html
The ignition switch can be adjusted by loosening the mounting screws, and sliding as described in above link.
A clunk while jumping the starter relay'(on the inner passenger fender liner) two large posts indicates bad starter relay contacts, bad wiring to starter, bad starter, corroded connections or a frozen engine.
Reactions: bsd4083
Yo,
Forgot to include, with a large screwdriver, jump the two large studs on the starter relay to see if starter cranks over.
Reactions: bsd4083
1 - 3 of 3 Posts
