1 - 4 of 4 Posts
Stuck like a MoFo
I need to get my winch setup finished which is a MM 10.5k Hydro witht he integrated solenoid setup. Since I am too cheap to buy 2 winches this will be going front to back but that doesn't really matter right now.
I want to run the stock PS lines so i can easily replace them when there is a prob. So i was thinking a T(pipe thread) off the back of the pump, then a fitting adapting it to the Flare of the pump back to the pipe thread T. The winch hydro line is JIC so i know i can find an easy fitting for that.
BTW i will be using a valve after the T so only when i want to use the winch fluid will be flowing through the extra lines.
So what size are the Flared fittings going into the back of the box, anybody know a good online supplier of them?
The pump is off an early 80's E Series van
FSB warrior
I could probably measure since I have my pump out right now
FSB warrior
it was 16tpi, meaning its not a pipe thread
Stuck like a MoFo
thanks :beer
yea i know its not pipe, i was jsut thinking a pipe T is the easiest to get, then use an adapter to change it the the Flare fitting of the PS pump...
1 - 4 of 4 Posts
