1 - 14 of 14 Posts
huh
1995 Bronco, Slightly Modified
Skyjacker Dropped Pitman Arm 6-8" lift 80-96
Up for sale is one used pitman arm for a 6-8" lift. part number FA600. It came with my old ttb 8" lift. When i did the straight axle swap i used the arm with chevy tie rod ends so i had to ream it to accept the bigger TRE's.. Im going to a smaller pitman arm now that my truck is a bit lower. So if you are doing an axle swap and will be using the heavy duty chevy tie rod ends this arm will work for you.. they sell for 120-150 bucks... ill let it go for 50 bucks plus shipping. ill snap some pics tomorrow
zip--90247
huh
Gub_Ni said:
I have a 78 Bronco. Any chance it will work? Will the chevy ends attach to my current steering?
i think the splines are different where it attaches to the gearbox... the chevy ends will work with your axle if you ream the knuckles.. i have a reamer floating around the country if you need to use it..
your 78 bronco would use a skyjacker pitman arm number FA300 (4-6") or FA500 (6-9")
:lolup :histerica eewwww
1 - 14 of 14 Posts
