1 - 14 of 14 Posts
Has anybody re-notched a bucket seat so it will slide further back? Can this be done and has anybody done it?(saw nothing in the search!) I have high shoulder OEM buckets in an 84'. I'm 6'5" eating the steering wheel!
Charlie don't surf..
'92 Ford Bronco XLT
Why not just remount the brackets moving them further back?
I THOUGHT ABOUT THAT BUT THERES A HUMP JUST AFTER THER FRONT BRACKET SO IF I DID THAT IT WOULD BE PERMENTLY TILTED BACK....
I KNOW ITS A WEIRD POST.... JUST SEEING IF ANYBODY HAD TROUBLE FITTING LIKE ME AS FAR AS LEG ROOM AND I'M NOT EVEN FAT!
might try the newer captian seats they sit farther back. i was eating the wheel in my 83 but the new seats i need to run one click up from full rear extend ot i miss the pedals. plus the arm rests are very nice...mike
green ones make me horny
What are you driving a bronco 2 i am 6'7 and 320 and i am fine in my truck plenty of room
No, it's a fullsize, just feel too close to the wheel. I know the newer models 90's and up sit a lot better for tall guys.
ive sat in both. unless you got bench seat. now those suck cause they are right there.
Banned
Personally, I'd like more rearward tilt in the seat base - I feel like it supports my legs better. But if you don't, just build some brackets that lift the seat evenly, AND shift the mounting points rearward. You should have no trouble fitting them between the factory tilt brackets & the seat base.
Teddy Bear
new seats in my opinion is the way to go, got mine from a 99 f-150, mounted them on the stock brackets, as far foward as i could on the sean an now i sit a little higher and a little farther back
1 - 14 of 14 Posts
