I have a 1989 eddie bauer edition 351 5.8L. when i drive my bronco on the street it accelerates way too slow. the engine doesnt rev or slip it gaines rpm normaly and in sync with my speed. my check engine light came on and im geting codes 67,41, and 63
according to my book
67=improper signals are being sent from either the Nuetral Drive Switch, Nuetral Gear Switch, Nuetral Pressure Switch, Manual Lever Position, Air Conditioner Clutch, or A/C was on during test(it wasnt i checked)
41=Exhaust Gas Oxygen (EGO) sensor: voltage signal always "lean" (low value)- Does not switch
63=Throttle Positioning Sensor (TPS)- Signal voltage is too low
now i just recently replaced my TPS because my bronco ran like crap (do codes auto-delete once the problem has been fixed?) and it fixed the problem. my haynes book says nothing about a "Exhaust Gas Oxygen" sensor. also my A/C doesnt even work. my heater works and it will blow air but it isnt cold.
help plz?:whiteflag
help plz?:whiteflag
