1 - 8 of 8 Posts
Ok I have the pump but everything else was taken off before I bought it 11 years ago but this is the first time I've had to have it because Nashville does annual emissions tests. What I wanna know is, are the parts I need easy to get and roughly how much I should be looking to spend for the parts
yo TN,
A yard queen is best source, then try Rockauto.com, AMAZON, etc.
BTW, The 96 5.8 is slightly diff from the 96 5.0 because Ford deleted the Smog Pump, Thermactor Air Control Solenoids, etc. from the 5.8
This is by Ford for 96; "The mechanical AIR system uses a belt-driven pump as well as a check valve to deliver air into the exhaust system where required. The belt-driven air pump runs continuously so a bypass valve and/or diverter valve is used to direct airflow to the exhaust manifold (upstream air), the COC catalyst (downstream air), or directly to
atmosphere (bypass/dump).
The Mechanical AIR pump flow check monitors the HO2S signal at idle to determine if secondary air is beingd elivered into the exhaust manifold (upstream). The air/fuel ratio is commanded open-loop rich, the AIR bypass/diverter valves are directed upstream, and the time required for the HO2S signal to go lean is monitored.
If the HO2S signal does not go lean within the allowable time limit, a low/no flow malfunction is indicated. (P0411)
If the vehicle is equipped with a COC catalyst, the downstream air delivery as well. The air/fuel ratio is commanded open-loop rich, the AIR bypass/diverter valves are directed downstream, and the time required for the HO2S signal to go lean is monitored. If the rear HO2S signal does not go lean within the allowable time limit,
a low/no flow malfunction is indicated. (P1411)
The PCM outputs that control the bypass and diverter valves are checked for circuit continuity (P0413, P0414 Bypass valve), (P0416, P0417 Diverter valve).
Currently, the 4.9L E and F-Series, 5.0L E and F-Series, and 7.5L F-Series incomplete vehicles utilize mechanical air system."
This is my 96 5.0 Vehicle Emission Control Information (VECI) Decalwith Vacuum Diagram & Calibration Parts List by FORD
for CALIBRATION: 6-64B-R05
See Vacuum Diagram, VECI Lable in attachments below;
also here is the Parts List for the 96 5.0
NAME/DESCRIPTION ENGINEERING NO. SERVICE NO.
SENSOR ASSY, Catalyst Exhaust Gas Oxygen Monitor- DOWNSTREAM F65F 9G444-CA F65Z 9G444-C
RESERVIOR ASSY, EGR Vacuum F4UE 9E453-CA F4UZ 9E453-C
CONTROL ASSY, EGR Vacuum Regulator FOTE 9J459-A1A FOTZ 9J459-A
SENSOR ASSY, EGR Pressure Valve F48E 9J460-BA, BB F4ZZ 9J460-B
VALVE ASSY, Thermactor Air Control Solenoid Vacuum E7TE 9H465-AA E7TZ 9H465-A
VALVE ASSY, Thermactor Air Control Solenoid Vacuum E7TE 9H465-BA E7TZ 9H465-B
SENSOR ASSY, Exhaust Gas Oxygen - UPSTREAM F68F 9F472-AA F68Z 9F472-A
VALVE ASSY, EGR F27E 9D475-A2B, A4B F2TZ 9D475-A
TUBE ASSY, EGR Valve to Exhaust Manifold F6TE 9D477-ED, EE F6TZ 9D477-E
PUMP ASSY, Thermactor E5TE 9A486-DB E5TZ 9A486-D
VALVE ASSY, Thermactor Check - Hose Nipple One End-Press in Tube Other End - DOWNSTREAM E8DZ 9A487-A
VALVE ASSY, Thermactor Check - 3/4-14 Thread One End-Hose Nipple One End - UPSTREAM E9VZ 9A487-A
VALVE ASSY, Thermactor Control E9AE 9F491-AA F0AZ 9F491-A
INJECTOR ASSY, Fuel F2TE 9F593-A3A F2TZ 9F593-A
VALVE ASSY, Throttle Air By-Pass F4TE 9F715-AA F4TZ 9F715-A
REGULATOR ASSY, Fuel Charging Pressure F4TE 9C968-BA F4TZ 9C968-B
POTENTIOMETER ASSY, Throttle Position Sensor F6TF 9B989-AA F6TZ 9B989-AA
DISTRIBUTOR ASSY F2TE 12127-AA F2TZ 12127-A
SENSOR ASSY, Mass Airflow F5UF 12B579-BA F5UZ 12B579-BA
SENSOR ASSY, Engine Electronic Control Coolant Temperature F5AF 12A648-AA F5AZ 12A648-A
PROCESSOR AND CALIBRATOR ASSY, Powertrain Control Module - EEC-V - TYPE: ML1-441 - REPROGRAMMABLE F6TF 12A650-PC F6TZ 12A650-PC
SENSOR ASSY, Air Charge Temperature F5AF 12A697-AA F5AZ 12A697-A
Cross-Over Tube, Diverter & Check Valves & Hoses Location in Parts Break-Out Diagram in a 96 w/Ford part numbers
Source: by Ford via miesk5
See Ford's On-Line Parts Catalog @ http://www.fordparts.com/Commerce/CatalogResults.aspx?y=1996&m=Ford&mo=Bronco#Search
Look through diagrams and see info on part numbers, etc; suvh as;
Secondary Air Injection Check Valve Hose
5.0L; D/L=6.48''. Attach to 9F491 valve
Thermactor Air Diverter (TAD), Thermactor Air Diverter (TAD solenoids & TAD Valve other components Location pic in a 5.8; miesk5 Note; same location as in my 96 5.0
also see;
Combination Air Bypass and air diverter valve Location & check valves depiction
Overview & Diagram @ http://www.supermotors.net/registry/media/589993
Thermactor Air Bypass Solenoid (TAB, AIRB, AM1); "...is controlled by the EEC-IV computer and provides vacuum to the Air Bypass/Air Control Valve. With vacuum present, air flows through the secondary air injection system. With no vacuum, the air from the air pump is dumped to the atmosphere. Essentially, this turns the secondary air injection system on or off. The secondary air injection system adds air to the catalytic converter to improve the burning of NOx gases. This reduces emissions..."
Source: by Ted F
Thermactor Air Bypass/Air Control Valve; "...based on vacuum input from the Thermactor Air Bypass Solenoid, and the Thermactor Air Diverter Solenoid, this valve controls the flow of air from the air pump to the exhaust manifold and the catalyst..."
Source: by Ted F
Tab and TAB pic in our 96;
Air Inlet Tube Location pics at Catalytic Converter in an 89 5.0; w/High Temperature Silicone Hose
Source: by rcracerx at http://www.fullsizebronco.com/forum/showthread.php?t=126881
Onepic for example
Air Inlet Tube (4 Air Inlet Tube 9J454) Location at Catalytic Converter in Exhaust System Parts Break-Out Diagram in 96 5.0L & 5.8L
Source: by Steve83
http://www.supermotors.net/registry/media/72365
Typical EFI Vacuum Lines (V8 shown; I6 similar)
http://www.supermotors.net/registry/media/894687
by Steve83
Vacuum Line (Hose) Sourcing; "...Get the Silicone Boost/Vacuum Hose Engine Dress Up Kit and then an additional 10' of 4mm vacuum hose in the color of your choice. I used wire loom to protect the hose through the Intake Manifold, to the Diverter Valve and where it rubs on the Intake to the EVP: Silicone Intake Systems..."
Source: by Seattle FSB (SeattleFSB) at FSB
A good Part source is PCI Inc,
EGR Tube (also called, AIR Tube), Crossover Tubes, Check Valves, O2 Sensor Repair Bungs, High Temp Silicone Hose, etc. for Bronco & all Ford, w/Ford Part Numbers & pics; http://www.pciinc.com
great customer service!! they see direct or thru NAPA..etc.
Sample products;
[Click Here to Enlarge Image]
Ford Air Tube $29.26
•85-96 5.0 Bronco; See Aps for more.
•Replaces O.E. E6TZ-5F235-B
•Use with #39 valve.
•Use with #7 clamp.
Ford Air Tube - Crossover With Threaded Stub $64.40
•85-96 302 eng. Ford trucks, EFU 150/250 Van, Pickup, Bronco, EFI
•Replaces OE E7TZ-9B449-A and F6TZ-9B449-F
•Similar to our #41V but has threaded stub.
•Use with #37 valve.
•Complete with two #56 gaskets.
See 96 Bronco 5.0 Emission Vacuum Diagram attachment below
I'll post for now and add more later.
The Anti Yam!
Does Nashville do a visual inspection?
If not, just make sure the EGR is working and that you have a good modern 3-way cat and it will pass the sniffer just fine.
If they do have a visual emissions control inspection, find a Pull-A-Part and look forward to spending the weekend there.
yo,
For a YARD SEARCH on-line, I use;
http://www.hollanderparts.com/
Select All Parts
year, etc, then FORD TRUCK
or
http://www.copartfinder.com/finder/searchMake.do
Has Vehicle Pics!
http://www.picknpull.com
This is a Company name w/yard locations in various states
Also for obsolete parts by Ford pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
Emission Sys Vacuum Tank (VRESER, Vacuum Reservoir - looks like a coffee can in earlier years)
Location pics in a 95 5.8 (he replaced it w/Peanut can)
https://www.supermotors.net/registry/22712/75627
Source: by fordbronco1995 ("JUICE") he replaced it w/Peanut can
The Vacuum Reservoir (coffee can) stores vacuum and provides "muscle" vacuum. It prevents rapid fluctuations or sudden drops in a vacuum signal such as those seen during an acceleration period.
Diagnosis; When charged initially with 15-20 in-Hg vacuum, vacuum loss shall not exceed 0.5 in-Hg in 60 seconds. If it does, replace the reservoir.
Vacuum Check Valve; A vacuum check valve blocks airflow in one direction and frees airflow in the other direction. The check side of this valve will hold the highest vacuum seen on the vacuum side. If not, replace it.
Vacuum Check Valve Diagnosis -
Apply 16 in-Hg vacuum to "check" side of valve and trap. If vacuum remains above 15 in-Hg for 10 seconds, the valve is acceptable
FPRC: Fuel Pressure Regulator Control. located on driver side
MAN VAC is Manifold Vacuum;
CAT is the catalytic converter
ENG is the engine
VMV is Vapor Management Valve ; located on passenger side firewall, high in our 96 5.0L; miesk5 note; for OBD II, The vapor management valve (VMV) replaces the canister purge valve used in EEC IV
Here is our VMV
Wiring Diagrams in 96 5.0;
http://www.revbase.com/BBBMOTOR/Wd/DownloadPdf?id=7201
Because its OBDII, the computer says it's not hooked up even without visual inspection
I was under the impression that 96s didn't come with the Thermactor system.
As far as the code is concerned, the computer is looking for the O2 sensors to go lean when the Thermactor system injects air into the exhaust manifold. It's not seeing it go lean which is why its throwing a code. You'll need to replace the Thermactor system to get it working again.
Your gonna have to go to a junkyard and pull the entire system from another truck, there's too many parts to buy individually and piece together.
Because it's emissions related and it has to be installed (depending on where you live) to pass the required smog test, you will out the a$$ for parts.
yo p,
The 96 5.8 Bronco did not come from factory w/Secondary Air System
The 96 5.0 Bronco came with Mechanical AIR System Monitor, aka Secondary Air System
This is by Ford in "1996 MY OBD System Operation Summary for Gasoline Engines @ http://www.motorcraftservice.com/vdirs/diagnostics/pdf/obdsm963.pdf
"...Currently, the 4.9L E and F-Series, 5.0L E and F-Series, and 7.5L F-Series incomplete vehicles utilize
mechanical air system..."
1 - 8 of 8 Posts
