1 - 14 of 14 Posts
A couple months ago I noticed my mileage suddenly dropped from a reliable 12-13mpg to 10mpg and has stayed at 10mpg ever since. For the life of me I could not figure out WHAT happened to warrant the sudden drop in fuel economy.
Until today.
I was removing my running boards and decided to have a look around (BTW, how important is it that the transmission pan be straight?), and what did I find? Aparently, I hit a rock that decided to come up and hit my exhaust such that the part of the Y pipe going to the driver's side is crimped about half-shut. "So THAT'S why my mileage dropped!" :toothless
Has anyone else done this? Has anyone tried to protect it? (or the transmission for that matter) And can I try tapping it out, or should I just wait it out until I can get a decent Y pipe?
dented pan. Sorry, I'm thinking bodywork terms... It's bolted securely, no leaks, but there's a few nice dents in it.
ASSSSS-HOOOOOLE
My y-pipe is dented, and i've got a pretty bad exhaust leak on the passenger side as a result, tweaked the mount and everything, never seen an exaust skidplate before, just figured i need more lift and bigger tires.
Yeller
Yeah- I did it-SO WHAT !!
Most every Bronco I've seen has a skidplate on it.Ford E7TZ 7E005 A,if you don't have one scrounge around the salvage yards, You can add an extension shield where needed under the pan by fabbing a some sheet steel and drilling bolt holes so that the trans is servicable. Depending on the amount of exhaust damage I'd probably just replace that section.
Zombie Hunter
I'd take the time to replace the pan....thats just me though. As picky as these tranny's are, i would just find a used one and put it on.
Got a pic of the plate?
OldYeller, that's exactly what I was thinking! The real irony is I found it the same day I stepped up from 31s to 33s (w00t! Tires bigger than my waist!)
Edit: Good point Rob. Why tempt fate further eh? Do they make tranny skid plates?
ASSSSS-HOOOOOLE
BRONCFOOT said:
Most every Bronco I've seen has a skidplate on it..
Are you talking about an exhuast skid or a tranny skid, mine came stock with a tranny skid.
EDIT: or at least the PO fabbed one up, I'll get a pic on here one day, but don't hold your breath.
Engineer
That's a transfer case skid plate not a transmission skid plate
Discussion Starter · #14 ·
Okay okay, so no one makes a Y-pipe OR tranny skidplate? Guess I'll have to figure something out then. Any opinions on bolt-on skidplates? I could potentially make one piece or two pieces to cover everything I want down there (leaving everything inaccessable while it's on), but allow it to unbolt for access...
1 - 14 of 14 Posts
