Status
Not open for further replies.
1 - 2 of 2 Posts
For your consideration is a Ford C6 4x4 transmission complete with torque converter and transfer case adapter. This C6 has a small-block (SBF) case (289/300/302/351W/Etc).
It had a NP205 bolted to it prior to being pulled from the 78 Bronco it was in. I know for certain that a Ford NP203 and NP208 were also original equipment behind C6's in this configuration. The BW1345 and BW1356 should also bolt up, but you may need to adjust/fabricate the linkage. There were was a long and short transfer case adapter on the C6, this has the short adapter which measures approximately 5 3/4".
This transmission appears to be in very good condition. The fluid is clean. I have not had the pan off or inspected the internals. Pulled from a full-size 78 Bronco rolling chassis.
I have too many parts laying around and too many projects so it should to go to somebody who can use it. I'm right off I-75 in Sumter County, FL. I will consider meeting someone within a reasonable distance.
$150obo
1 - 2 of 2 Posts
Status
