Status
Not open for further replies.
1 - 20 of 50 Posts
Picked up a 79 Bronco with no title for parts. I will be keeping axles and suspension components, but everything else is up for grabs. Doesn’t have an engine/trans/t-case, but came with a mountain of random parts. As I pull parts out I will post them up here, but feel free to ask if you are looking for something specific. Located in Fernley Nevada, but I will work to arrange shipping or delivery
155201
Slider window hard top. Needs paint, and tint is peeling, but is solid $400
155209
155210
Discussion Starter #2 (Edited)
Stock ignition coil with bracket $5
155216
Discussion Starter #3 (Edited)
XLT Ranger gauge plastic bezel. Has 2 holes drilled in it, and simulated wood grain is peeling in one corner, but very usable $20
155223
XLT Ranger dash. Good used condition $50
155224
Defroster ducts. $5 each
155225
Washer fluid reservoirs. One is missing lid, other has one broken mounting tab. $5 for both
155226
Discussion Starter #4 (Edited)
emergency brake petal assembly $10
155228
Ash trays. $5 each
155233
Steering column plastic bezel. One is shorter than the other. Dunno what that signifies, I’m guessing auto vs manual column, or tilt vs non-tilt. Either way, $5 each
155234
If shipping wasn’t going to be a bitch to Oregon I’d take the light bar and lights! o_O
Anybody driving this way? :ROFLMAO:
I’m gonna try to get out there for Tom’s Bronco roundup thing in July. Dunno if someone else will buy them before that, but if they don’t I could bring them
I can send you a bank check if your cool with them sitting around till you come this way or since your close to Reno an excuse for a summer road trip might be good ;) Shot you a PM.
Addicted to Junk
Just fyi, the light bar isnt too much to ship if packaged right. I sent one to NY for export to @Oscar in Iceland, and it was like 30 bucks iirc.
Nice collection of parts nick, GL with the sale.
Reactions: Oscar and NickOille
Discussion Starter #10 (Edited)
Seatbelt covers $5 each
155250
Stock air inlet duct $5
155251
Rear ash trays $5 each
155252
Clutch equalizer bracket $20
155253
Discussion Starter #11
Non-ac heater/blower box $20
155254
155255
Gauge clusters. One has a crack in the clear lens, one has a broken mounting tab. Both are usable. $20 each
155256
Fresh air vent $5
155257
Tailgate access cover. Has one small spot of rust, but still very usable $10
155258
155259
Discussion Starter #12 (Edited)
Front seat belts. $10 for the pair
155273
Clutch petal $10
155275
Auto trans brake petal $10
155276
Discussion Starter #13
Frame horns with motor mounts, used. $20
155277
One visor and center bracket $10
155278
Front and rear sway bars. $40 for both
155280
Lot of front turn signals. None are show quality, some have chips/cracks and one of the right side ones is just the lens with no backing. $20 for all of them
155283
Marker lights, 5 red, 2 amber. Not show quality but usable. $20 for all of them
155285
Front headlight groups. Buckets, rings, plastic bezels, and 3 bulbs. $40 for everything
155287
Discussion Starter #14
Factory jack holder $5
155290
Trim pieces. Rear cargo area trim, door sill trim, and I think the other pieces are upper door trim, but I could be wrong. $20 for everything
155291
Fuel filler necks, both in good condition. $10 each
155292
Fuel doors. $10 each
155293
99% sure this is a 351m/400 power steering pump bracket. $10
155294
Discussion Starter #15 (Edited)
Good trans mount $5
155296
Stock fan shroud. Chip in corner but very usable.$10
155298
Two starters, one NOS, one used. Both work. I believe it should fit 351m/400/429/460. $10 for the used one, $20 for the new one
155299
You got anything AC or windshielf washer fluid related? How about other inside trim like door panels n such
edit: nvm the previous stuff loaded
Discussion Starter #17
Non-ac truck.... it has door panels still in the truck, I think they were a little rough but I’ll get pictures tomorrow
Reactions: canuckistan97
Addicted to Junk
If no one takes the two bronco emblems by the Safari, bring em and I'll buy em.
Discussion Starter #20
Body and frame are up for grabs too. No title, but is solid and rust free. $500
And I’m keeping the axles and springs
155388
155389
155390
155391
155392
155393
155394
Reactions: miesk5
1 - 20 of 50 Posts
Status
