1. The stock 351 intake would choke a 289.
2. Stock S.D. will not run that engine.
3. What year and what tranny.
I am 99.372% sure it is. Just check to make sure the 60 pin connecter has the same pinouts as your computer. If any are diferant just swap them out so that they are in the right place for the new computer. It's that simple.moses Black 89 said:Is the Lightning computer a direct swap.
You would have to either run two computers or buy an aftermarket controller like the Baumannator TCS.moses Black 89 said:A buddy of mine has a mass air setup off of a 91 mustang. That should solve my SD problems, but what will i need to do about the E40D.
Some use A-9 computers and a controller, some use later Mass-Air/E4OD computers from a standard pickup like the VEX-1.moses Black 89 said:so what your saying is unless i want to spend a tremendous amount of money im stuck with SD. Also what about the lightnings i see running aroud with MAF
I dont know, but I do know injector firing order is uninportant. But if you really wanted to wory about it you could switch the pins in the 60 pin connector to match.moses Black 89 said:I thought the standard truck maf computers only came in the 302 firing order.
or am mistaken
