The np435 to my knowledge was never offered for an EFI 351, but i have come to learn everything is very interchangeable no matter if carb'd or efi, or motor 300, 302, 351. My swap was 100% bolt in, even my newer tcase linkage bolted up to the older ('86) np435 tailshaft housing, i just had to get parts from a 87-91 and 80-86 matching everything to work with my truck, for example the clutch master is '89 for a 302 and the slave cylinder is for an '86 with a 302, flywheel is for a '86 with a 351, and so on...
1986 np435, got it from the same truck i got the 9" out of at picknpull:
Stock replacement 11" clutch set and stock Flywheel:
Pedals, backing plate, and floorpan:
New starter:
C6 out:
435 in:
reassembly:
BEFORE:
AFTER:
Shift knob:
Its a blast to drive now, geared locked and manual, i just need to swap in the solid dana44 i have laying in the garage :imp
Adding to that, save for the obvious bell differences... add 460 to your interchange numbers...
Did this to my '90 7.5 powered C 350 last fall.
trans is 80 f100 4.9 4x4 t case is my 1356 from behind E40D, bell pac is from carbed 85 2wd F350.
Love it!
Just have to remember to wire up some back up lights,
unless you have the proper wiring harness to the trans.
I spliced the wires from the 435 to the c6 harness so the back up lights work and the neutral safety switch wires are looped together
I know this is a little old but do you have any good pics of the tailshaft coming out of that 435?
I have one on my truck that is bolted to a dana 21 and i have one that is newer that had a 205 on it and i was wondering if they have different tail shafts, splines. etc
Say..I'm converting to a 351w and have a np435..I'm still not 100% clear on what flywheel, pressure plate ect to use?..you used an 11inch..is this what it calls for? or should I match what ever size flywheel my 300 has and get the same size for the 351?..just not sure
