If you're having problems with your shifter not going into park or reverse, or the indicator being whacked, definitely use the search function. You'll find this thread, probably: http://www.fullsizebronco.com/forum/showthread.php?t=51613&highlight=column+shifter which is chock full of valuable info and of course Steve83's amazingly helpful pictures of every dang part of a Bronco. This was very useful to me earlier today when my 94 chose not to go into park.
However, if you look before you leap, you will save yourself a lot of hassle. I dropped the column completely (about an hour of work, including setup, in the single-digit weather we're having in beautiful Michigan this evening), only to find that it was just loose screws on the back of the shift rod (near the orange fingers in the pictures in Steve's post to the above-mentioned thread, which, when the column is installed, puts them straight up from the brake pedal). I had one of them fall on my foot, and the other was loose. They are easily replaceable/tightenable without removing any panels, though if you're a fatass like me, pulling the knee panel helps. You certainly don't need to drop the column, as I did.
Just hoping that saves someone some trouble. Oh, and if you *do* need to drop the column, here are some more tips:
The tilt handle unscrews, and even has flats on the rod for a wrench.
If you need to take the top plastic shroud off the column, loosen the 4 nuts holding up the column after you take off the bottom shroud. The top will come off a *lot* easier then.
The nuts that hold up the column take a 1/2" deepwell socket.
Unhook *and* unbolt the indicator wire, to prevent excess stress on it. Only unhooking it is insufficient.
The golden Torx screws that hold the shift rod down and the cable arm onto the end of it (like the one that fell out on my foot) are T-30s.
Sorry if this is all repetitive of some other post, this is stuff I didn't find in my earlier searches.
(I don't have any pictures because it was too dang cold.)
