1 - 2 of 2 Posts
92 5.0 E4OD metallic root beer work in progress
I am attempting to replace the bushings on the hinge part of the swing away tire carrier on my 92. I saw a previous thread where the recommended bushing replacement part was part # 6659K32 from McMaster-Carr. The factory ones are no longer available.
So I removed the c clips from the pivot studs, but I can’t get them to budge. Even tried knocking them out with a hammer, with no luck. Does anyone have any suggestions on how to get them out, so I can replace the bushings? Thanks in advance.
I used the hammer method on mine. They were stuck in there pretty good and I had to put a smackdown on them to get them to move. Try heating them up with a torch and using PB Blaster.
1 - 2 of 2 Posts
