1994 Bronco Eddie Bauer Edition
Took the spare tire carrier off my '94 Eddie Bauer shortly after I bought the vehicle. The carrier has been at the coatings shop for a few weeks now and supposed to be ready for me tomorrow afternoon. Are there some critical things I need to be aware of as I get ready to reinstall it? Any parts that should be replaced proactively?
Thanks in advance.
i would think that proper alignment of the carrier to the support that's on the tailgate is critical
the bushings in the hinge at the rear quarter panel should be tight and clean (that squeak can drive you nuts)
the mechanism on the carrier that clamps on the tailgate support is a huge safety issue - make sure that's working flawlelssly
Reactions: DBStoots
Yo DBStoots,
Following from 1996 Bronco Workshop Manual @ 1996 Bronco/F-Series
Section 00-02: Lifting, Jacking and Spare Tire Stowage
1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual​
REMOVAL AND INSTALLATION
Tire, Spare, Carrier, Swing-Away, Bronco
Removal and Installation
For swing-away spare wheel carrier removal and installation, refer to the following illustration.
Swing-Away Spare Wheel Carrier, Bronco
Motor vehicle Font Auto part Gas Machine
ItemPart NumberDescription
11A401Locking Latch Bracket Reinforcement, Spare Wheel Carrier
21469Spare Wheel Carrier Support
3N606690-S55Screw and Washer
41433Spare Wheel Carrier
5N803207-S100Screw and Washer
61A429Spare Wheel Support
7388577-S150Pushpin
847104Spare Wheel Scuff Pad
957472-S2Screw and Washer
ATighten to 16-27 Nm
(12-20 Lb-Ft)
BTighten to 8-15 Nm
(6-11 Lb-Ft)
SPECIFICATIONS
SPECIFICATIONS
TORQUE SPECIFICATIONS
Description​
Nm​
Lb-Ft​
Lb-In​
Retainer, Spare Tire​
19-26​
14-19​
Nut, Spare Tire Carrier Support, F-350, F-Super Duty​
40-55​
30-41​
Wing Nut, Spare Tire Mounting​
4.1-4.7​
36-42​
Bolt, Inside Spare Tire Support​
30-43​
22-32​
Screw and Washer Assembly, Inside Spare Tire Support​
8-15​
6-11​
Nut, Spare Wheel Carrier Holder​
19-26​
14-19​
Nut, Spare Tire Carrier Support, Bronco​
16-27​
12-20​
Bolt, Spare Wheel Carrier Holder​
19-26​
14-19​
Nut, Spare Tire Carrier Support, F-150, F-250, F-350​
22-34​
16-25​
Screw and Washer, Spare Tire Carrier Locking Latch Bracket, Bronco​
8-15​
6-11​
Unless I missed it, the parts diagram doesn't seem to show the upper or lower corner support horns, or the 3rd piece that is secured to the tailgate, which I guess is used to mount the spare wheel carrier support. Can someone tell me what that is called? I am also wondering about the two pins that go through the holes in the corner support horns. I picked up my spare tire carrier from the shop that powder coated it today, and those parts are missing. So, when I call them on Monday, I want to be able to reference exactly what is missing. Turned out really nice. Thanks in advance!
Kitchen appliance Hood Data storage device Musical instrument Record player
Hood Bumper Table Automotive design Automotive exterior
