1 - 3 of 3 Posts
I noticed the design of Tailgate spare tire carriers are a little different throughout the years, but does anyone know if they are all compatible on all the 80-96 years? For example do all the holes line up for mounting.
Plagiarized from Steve83:
Yes. You can put any carrier on any year, as long as the cast body brackets fit the curve of the body corners & the latch fits the strike. You can ONLY put '80-86 body brackets on '80-86 bodies. But '87-96 brackets will fit '80-96 bodies. Also, '80-86 tailgate internal braces only have 2 nuts. So if you put on an '87-96 strike, you'll have an empty hole since they're made for 3 bolts. But it'll still fit & work. The '78~89 latch system is totally different from ~'90-96, so the latch & strike must match.
Thanx, what about a Bronco 2??
1 - 3 of 3 Posts
