Whats the high pressure PSI spec? I know the rail is 35-40, but the output of the pump must be significantly higher than that.Dustball said:Huh, who knew that Napa would list the specs online...
24 GPH
5 psi
High pressure in-line pump puts out 33 GPH.
Looks like that Mr. Gasket in-line fuel pump I installed in an emergency when the in-tank pump failed will be there to stay. Specs for that pump is 4-7 psi and 35 gph.
