I need a new speedo gear in my 205 transfer case Is the one in a 2wd four speed transmission the same as the one in the transfer case?
No, the splines are reversed on a tranny's speedo gear. I've got a few 205 speedo gears. Count the teeth you have and let me know.I need a new speedo gear in my 205 transfer case Is the one in a 2wd four speed transmission the same as the one in the transfer case?
Man for some reason I just figured that the speedometer didn't work in reverse, but I bet you're right. It's probably ready to be replaced. Thanks for the idea. I'll test it and reply back this weekend.Sound like the speed o meter is bad
try driving in reverse. My guess is it works in R only
So I bought a new speedo from BG and it only works in the counter-clockwise position as well. I haven't installed it yet but spinning it with my fingers will only net movement in the counter-clockwise rotation. Did I get a faulty gauge?They work in R. I understand why you would think they do not. I just have happen to looked down at mine backing up out of a long drive way and found it interesting to see the needle move.
