1 - 9 of 9 Posts
Has anyone actually used the cal number calibration method on the 92-96 BKO's, to fix tire diameter or gear ratio changes? If so is there a formula for figuring out the proper cal number. Unfortunately these guage clusters can only be reprogrammed 5 times so I would like to get it right within two tries.
Ford Hoarder
78 & 92
I did that on mine.
Preety simple, and got it within 1 or 2 when it was 7 off
Your welcome......and the procedure itself is very easy.
Hmmm....
i think i am going to do this tomorrow, but how exactly do you ground the wire??? i know this sounds noobish but maybe i am just having a brain fart
My transmission shifts better after the callibration also. It makes a difference when the speedometer knows the correct speed your going when it tells the trans. to shift.
Yeah, you may want to do that before you get pulled over for going "70"
:histerica
Kenny I'd just like to say that you have the most attractive truck in this community. :hump
1 - 9 of 9 Posts
